How abusive of notation is it to drop isomorphisms?
  • Thread starter Thread starter icantadd
    Drop Notation
icantadd
I have a general sort of structural question. I have been reading a lot of maths papers lately, and it seems there are some isomorphisms that people omit from their calculations. For example, in a category with a terminal object, 1,
A \cong A \times 1
where the isomorphism is given from left to right by \langle 1_A , !_A \rangle where ! is the unique map into the terminal object, and the isomorphism from right to left is (left) projection. Now, let a : 1 \to A; an example of the abuse of notation I have seen quite often is to regard
\langle a , 1_1 \rangle : 1 \to A \times 1 as just a
Are there any obvious problems with making such an association? Are there any non-obvious problems with making such an association? Am I missing something?
Mathematics would be much more difficult to read if we didn't make such identifications. Usually, there are no problems with it, but you should always keep in mind that you made the identification. Sometimes you can find yourself very confused about something, and it turns out you forgot you identified some things previously. But normally, there are no problems...
Thank you for the reply!
##\textbf{Exercise 10}:## I came across the following solution online: Questions: 1. When the author states in "that ring (not sure if he is referring to ##R## or ##R/\mathfrak{p}##, but I am guessing the later) ##x_n x_{n+1}=0## for all odd $n$ and ##x_{n+1}## is invertible, so that ##x_n=0##" 2. How does ##x_nx_{n+1}=0## implies that ##x_{n+1}## is invertible and ##x_n=0##. I mean if the quotient ring ##R/\mathfrak{p}## is an integral domain, and ##x_{n+1}## is invertible then...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
When decomposing a representation ##\rho## of a finite group ##G## into irreducible representations, we can find the number of times the representation contains a particular irrep ##\rho_0## through the character inner product $$ \langle \chi, \chi_0\rangle = \frac{1}{|G|} \sum_{g\in G} \chi(g) \chi_0(g)^*$$ where ##\chi## and ##\chi_0## are the characters of ##\rho## and ##\rho_0##, respectively. Since all group elements in the same conjugacy class have the same characters, this may be...
