How are ultra cold temperatures measured?
The discussion revolves around the measurement of ultra-cold temperatures, specifically in the nanoKelvin range. Participants explore the methods and technologies used for measuring such low temperatures, including the challenges associated with direct contact and the effects of vacuum conditions.
  • Some participants mention that ultra-high vacuum is required for measuring ultra-cold temperatures.
  • Laser cooling and magnetic refrigeration are proposed as cooling technologies that can be utilized.
  • One participant suggests that measuring the velocity distribution of atoms provides a means to infer temperature, with a narrower distribution indicating colder temperatures.
  • A later reply questions how the velocity distribution can be measured without significantly heating the system.
  • Another participant describes a method involving the expansion of a cloud of atoms after releasing them from an optical trap, suggesting that the expansion rate can be used to infer temperature.
  • References to specific methods described by Bill Phillips are provided, including techniques for chirp cooling and time of flight (TOF) methods.
Participants express uncertainty regarding the measurement techniques and whether older methods still apply in the nanoKelvin range. There is no consensus on the best approach to measure ultra-cold temperatures.
Some limitations include the dependence on specific measurement techniques and the potential impact of vacuum conditions on the measurements. The discussion does not resolve the challenges of measuring ultra-cold temperatures without heating the system.
widderjoos
How are ultra cold temperatures measured? For example, sometimes I see things measured in nanoKelvins. I'm thinking there has to be direct contact since the vacuum is already hotter than this, but how is it actually done?
It requires ultra high vaccum.
And the cooling technology can be utilized is "Laser cooling" and "Magnetic refrigeration".
It comes from measuring the velocity distribution of the atoms. A narrower distribution corresponds to colder temperatures.
That does not address the question, which is, how are these cold temperatures measured?
Thanks, but how do they measure the velocity distribution without significantly heating the system up?
I'm more familiar with measurements in the μK range that were common 20-or-so years ago. I'm not 100% sure if they still work in the nK range -- I believe they do, or some variation of them -- but here is a brief explanation:
After cooling and trapping atoms the optical trap is shut off, releasing the atoms that had been trapped. The collection of atoms then expands, owing to the different velocities of the atoms. Loosely speaking, the amount of expansion of this "cloud" of atoms is measured some time later. The expansion rate is a measure of the velocity distribution, from which the temperature can be inferred.
For more details, Bill Phillips has nicely described several methods, all relying on the expansion of atoms after shutting off the trap:
http://prl.aps.org/files/RevModPhys.70.721.pdf
One method described on p. 730 (p. 10 of the pdf file), in the paragraph that begins "Using the techniques for chirp cooling, ..."
A second method is described starting at the bottom of p. 731, in the paragraph that begins "In this time of flight (TOF) method,..."
Two more methods are described briefly, on p. 732, in the paragraph that begins "Another method was the 'fountain' technique..."
Hope that helps.
Thanks, this helped a lot
  • · Replies 20 ·
  • · Replies 32 ·
