How Can a Generic Vector Be Decomposed Using the Helmholtz Theorem?
Legion81
I have to show that a generic vector can be decomposed into an irrotational and solenoidal component:
V(r) = -Grad[phi(r)] + Curl[A(r)]
I'm not sure how to start. Do I need to take the curl or div of V and use a vector identity? Any help would be greatly appreciated!
Helmholtz' Theorem starts with the two components in my original post and defines the divergence and curl as:
div[V] = s(r)
and
curl[V] = c(r), where div[c(r)] = 0
But I can't find anything about how we can define a generic vector as two components:
V = -grad[phi] + curl[A], where "phi" is the scalar potential and "A" is the vector potential. I need to do this before I can show that s(r) and c(r) uniquely specify the vector.
I hope that makes my problem a little more clear.
Taking the divergence/curl of both sides of this equation seems like a good place to start. What do you get when you do that?
P.S. You may wish to use boldface font to denote vectors, to make things clear.
I actually just found an easy way of showing it using projection operators. Thanks for the reply.
Consider this question solved.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
