How can i calculate pressure drop in air compressor?
To calculate pressure drop in an air compressor system, the flow regime must be considered, with incompressible flow equations like Darcy-Weisbach applicable when air velocity is below 0.3 Mach. For velocities exceeding this threshold, compressible flow analysis is necessary. The Crane Technical Paper 410 provides guidance on compressible flows, which can be useful for air and gas systems. A formula from the Atlas Copco manual can also be employed for calculating pressure drop, factoring in air flow, pipe diameter, length, and initial pressure. In the given example, the calculated velocity is 22.08 m/s, indicating that incompressible flow equations can be used for this scenario.
noname91
hi friends,
I am confused with incompressible and compressible flow.Can i use moody diagram for air compressor.How can i calculate pressure drop in pipe.
As long as the velocity of the air flow < 0.3 Mach, the incompressible flow equations (Darcy-Weisbach) can be used to calculate pressure drop in a piping system. Once speed > 0.3 Mach, then a different analysis using compressible flow is called for.
I don't know what you mean by 'Can I use moody diagram for air compressor?'
Crane Technical Paper 410 covers some simple compressible flows for air and other gases. It's worth laying your hands on a copy.
I found a formula from atlas copco manual
p1-p2=(450*(q^1,85)*L)/((d^5)*p)
q=air flow (l/s)
d=internal pipe diameter(mm)
l=length of the pipe bar(a)
p=absolute initial pressure
atlas copco products air compressor.Can i use this formula to calculate pressure drop in pipeline?
It's worth a shot. Remember, pressure is in units of bars.
air compressor Q=2,6m^3/min D(diameter)=50mm P(pressure)=7,5Bar
V=Q/A ---> V=4*(2,6/60)/(3,14*0,05^2)
V=22,08m/s MACH=22,08/340=0,064
Can i use incompressible flow equations(DARCY-WEİSBACH)?
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
