How can I calculate underwater pressure quickly
The discussion centers on calculating underwater pressure using the formula P = ρgh, where ρ is fluid density, g is gravitational acceleration, and h is the height of the fluid column. Participants confirm that this formula is effective for practical applications, noting that an additional atmospheric pressure of about 1 atm is added for every 10 meters of water depth. They also discuss the conversion of pressure units, specifically from pascals to bars, with 1 bar equating to 100,000 pascals. The importance of considering initial atmospheric pressure at sea level is highlighted, especially in contexts like submarine analysis. Overall, the formula P = ρgh remains the standard for calculating hydrostatic pressure.
Charlie Kay
Does anyone know a simple formula to calculate underwater pressure?
I have the formula "P=r*g*h" when r=fluid density, g=Acceleration of gravity and h=height of fluid.
Got this off NASA
Same thing. (##\rho## is the common symbol for density.)
The simplest way you can get is 1 extra atmospheric pressure per 10 metres of water column.
Brilliant, that's just what I was looking for! :-)
How much Is normal atmospheric pressure?
1 atm or very close to 1 bar, or very close to 100 000 Pascals.
In the spirit of the forum I'd encourage you to take the earlier-posted equations and plug in the numbers for 10 metres of water, and see if it really comes down to 100 000 Pascals. You need density of water in kg/m^3.
Of course Bandersnatch's answer is an approximation - but quite good enough for all practical purposes. It would be a good exercise to calculate exactly what the pressure increase from ten meters of water is using the ##\rho{g}h## formula - google will find the values of the various physical constants you'll need - and see just how good of an approximation it is, whether it is sensitive to small changes in the temperature of the water.
Just wandering if there are any other formulas for it?!
##\rho{g}h## is pretty much the gold standard here. You can make additional corrections if ##\rho## or ##g## aren't constant, but for any problem involving reasonable liquids on or around the surface of the earth, these are just rounding errors.
Hey guys I've collected some information and I can now calculate "P=r*g*h" It is:
999.99 X 9.81 X 11000 = 107 908 920.9
Fluid Density X Acceleration Due To Gravity X Height Of Fluid = Pressure
But this is it pascal, does anyone know the conversion rate from pascal to bar?
1 bar = 100,000 Pa.
While we appreciate the traffic, Google will answer these questions in milliseconds...
Likes Chestermiller and Doc Al
And don't forget what 'snatch said: "1 extra atmospheric pressure per 10 metres".
People often forget there's an initial 1 atm at sea level.
That often falls out of the analysis (for example, for a submarine), but yes, that thought should at least be processed at the start of the analysis.
But it's not as friendly and it doest'n give you a straight answer
It certainly has its limitations, but it is a life-skill everyone should have.
