How can I design and make a 1750khz IF transformer
The discussion focuses on designing and constructing a 1750 kHz intermediate frequency (IF) transformer for a tube project. Users suggest modifying existing 455 kHz transformers by removing turns to increase frequency, while also addressing impedance changes. Recommendations include creating tuned circuits with inductors and capacitors, specifically using 470 pF capacitors with 18 μH inductors to achieve resonance at 1750 kHz. The conversation highlights the historical context of using Litz wire in IF transformers and the challenges of sourcing suitable components.
  • Understanding of RF circuit design principles
  • Familiarity with inductors and capacitors in tuned circuits
  • Knowledge of Litz wire and its applications in transformers
  • Experience with signal generators for resonance testing
  • Research the construction of custom IF transformers using toroidal cores
  • Learn about the effects of winding configurations on transformer performance
  • Investigate the use of signal generators for tuning circuits
  • Explore sourcing options for vintage AM band oscillator transformers
Electronics hobbyists, RF engineers, and anyone involved in vintage tube projects or custom transformer design will benefit from this discussion.
Southern
I am in need of some 1750khz intermediate transformers for an old tube project. I can find a few 455khz but not 1750khz. Removing turns from a 455khz IF transformer would raise the frequency but what would that do to the impedance?
I thought I would be able to find quite a bit on the subject of rolling my own IF transformer either with a toroid or on a coil form but saw very little and find no 1750's listed for sale so I have to make my own.
I saw one 3 year old thread that asked the question but the thread was locked and no answer had been offered. Can anyone help me?
Thank you.
These IF transformers were never common, but, many years ago, you could just get an oscillator transformer from a AM band radio.
These cover a range 455 kHz above the received frequency, so they already covered 1750 kHz. You just needed a suitable capacitor to resonate them.
Now, all that is gone.
You could make some tuned circuits and resonate them if you have a signal generator.
You would make or buy some inductors then put a capacitor across each one and then ground one end of each tuned circuit. Then join the other ends with small value capacitors.
As a guide, 470 pF would resonate with 18 μH at 1750 kHz.
If you buy an inductor with an iron or ferrite core, the actual inductance will vary with frequency, so you would need to experiment with the capacitors.
What value capacitor does the 455kHz use in its IFTs? You might just be able to reduce it to get 1.75MHz.
I think the old valve receivers typically used Litz wire for their IFT's. It would be difficult to make a good joint if you remove some of that winding. Maybe poorer quality receivers might have used single-strand windings on the IFT core? (Does it need to withstand much voltage? If not, maybe a transistor radio might have single-strand windings on IFTs you could salvage and modify.)
I'm envious. What is your valve project?
Most likely this can only be answered by an "old timer". I am making measurements on an uA709 op amp (metal can). I would like to calculate the frequency rolloff curves (I can measure them). I assume the compensation is via the miller effect. To do the calculations I would need to know the gain of the transistors and the effective resistance seen at the compensation terminals, not including the values I put there. Anyone know those values?
  • · Replies 18 ·
  • · Replies 81 ·
  • · Replies 28 ·
  • · Replies 36 ·
12K
  • · Replies 28 ·
  • · Replies 23 ·
