How can I find a 1 um size vacancy under 150 um brass?
  • Thread starter Thread starter rain2air
To detect a 1 um size vacancy in solder between brass and copper tape, standard non-destructive testing (NDT) methods like X-ray and ultrasound can be effective for larger voids. For smaller voids, measuring through-thickness electrical resistance may reveal local variations indicative of larger voids. Acoustic time domain reflectometry and ultrasonic thickness gauges are also suggested as potential detection methods due to their sensitivity to acoustic impedance mismatches. The discussion emphasizes the importance of understanding the implications of voids in solder, as they can affect the performance of the joint. Preventing the formation of such voids is crucial for ensuring the integrity of the soldered connection.
rain2air
I have soldered a pair of brass tape on the both side of a copper tape.
The thickness of each metal tape is about 150 um(micrometer).
The thickness of solder is about 2~20 um.
I want to know what device can find the small vacancy of solder between the brass and the copper tape.
Depends on the area of the void . Very small voids will be difficult to detect by any method but larger voids that occur in normal soldered joints can be detected by a variety of standard NDT procedures . X ray and ultrasound detection are commonly used .
With these very thin layers you might be able to locate larger voids by measuring the through thickness electrical resistance at numerous points and detecting local variations .
Curious to know why you need to know if there is a 1u void? Presumably it makes a difference to some something? so can you use that "something" to help locate it?
You should be able to use acoustic time domain reflectometry, or an ultrasonic thickness gauge. There will be a significant reflection from the acoustic impedance mismatch where there is air between the laminated metals.
I want to prevent the void from being created in the solder.
Why does it matter? What will the void do? CWatters asked because if your application is X and you will get Y problem then in your test setup you could do a bit of X and try to detect Y. If you see a bit of Y then you have the void. That may not be true of your application but if it is then you have a good way of measuring it.
BoB
Likes Baluncore
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
