How can I find a 1 um size vacancy under 150 um brass?
  • Thread starter Thread starter rain2air
To detect a 1 um size vacancy in solder between brass and copper tape, standard non-destructive testing (NDT) methods like X-ray and ultrasound can be effective for larger voids. For smaller voids, measuring through-thickness electrical resistance may reveal local variations indicative of larger voids. Acoustic time domain reflectometry and ultrasonic thickness gauges are also suggested as potential detection methods due to their sensitivity to acoustic impedance mismatches. The discussion emphasizes the importance of understanding the implications of voids in solder, as they can affect the performance of the joint. Preventing the formation of such voids is crucial for ensuring the integrity of the soldered connection.
rain2air
I have soldered a pair of brass tape on the both side of a copper tape.
The thickness of each metal tape is about 150 um(micrometer).
The thickness of solder is about 2~20 um.
I want to know what device can find the small vacancy of solder between the brass and the copper tape.
Depends on the area of the void . Very small voids will be difficult to detect by any method but larger voids that occur in normal soldered joints can be detected by a variety of standard NDT procedures . X ray and ultrasound detection are commonly used .
With these very thin layers you might be able to locate larger voids by measuring the through thickness electrical resistance at numerous points and detecting local variations .
Curious to know why you need to know if there is a 1u void? Presumably it makes a difference to some something? so can you use that "something" to help locate it?
You should be able to use acoustic time domain reflectometry, or an ultrasonic thickness gauge. There will be a significant reflection from the acoustic impedance mismatch where there is air between the laminated metals.
I want to prevent the void from being created in the solder.
Why does it matter? What will the void do? CWatters asked because if your application is X and you will get Y problem then in your test setup you could do a bit of X and try to detect Y. If you see a bit of Y then you have the void. That may not be true of your application but if it is then you have a good way of measuring it.
BoB
Likes Baluncore
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
