How can I make position controlled motor ?
  • Thread starter Thread starter Anup yadav
    Motor Position
To create a position-controlled motor, consider using a stepper motor or a servo motor based on your specific speed and torque needs. Stepper motors are ideal for precise control of movement, while servo motors offer higher speed and torque capabilities. Gears may be necessary to enhance performance depending on the application. Understanding the requirements of your project will guide the selection of the appropriate motor type. Proper motor control can enable bidirectional movement effectively.
Anup yadav
I have no idea regarding it I just know that we can control a motor movement and
can move it both to and fro.
please help
Google stepper motor
Likes CalcNerd
For most applications you either want a stepper motor or a servo depending on speed/torque requirements you might also need gears.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
