Automotive How Can I Optimize Airflow Across Different RPMs for My Motorcycle Engine Build?
Optimizing airflow across different RPMs for a motorcycle engine involves understanding the relationship between engine design and air velocity. The engine in question has a bore and stroke of 56x47 mm and a compression ratio of 13:1, leading to specific airflow calculations at varying RPMs. The discussion emphasizes the importance of cam design in achieving productive airflow throughout the rev range, rather than focusing solely on peak horsepower. It is suggested to start with an existing engine design for practical learning before attempting a complete new engine build. Calculating mean gas velocities, ideally between 90 to 110 m/s, is crucial for maximizing volumetric efficiency.
puxley
Ok so here it goes,
I have a motorbike,and as I am a learning engineer I want to build a second engine for a few reasons, firstly I want to go faster secondly I want to do all the work myself to learn, thirdly I want to become a better engineer and want to do lots of paper work to learn and see how close I can get predictions.
I can see this as a very difficult undertaking as there are many veriables but nothing like a good challenge to get things going.
My problem is I need your fabulous help.
And if anyone wants to give me some homework and reading please push me in the right direction.
Ok the engine will have a bore and stroke of 56x47
It is a inline 4. We will say it is running a compression ratio of 13:1.
So with that being said will need a clearance volume of 10.7081cc per cylinder.
This would mean (not including the clearance volume) it "could" move 3726.498 lm @14500 rpm and 514.007 @ 2000rpm now is where it gets tricky, I would like to try find a flow rate that is productive through the rev range, how would I find out the the best air velocity to do this as I'm not too interested about massive cross sectional area for peak Bhp.
I also will not be near a flow bench till Jan so this is all just numbers to aim for until then. As I understand it (correct me where I am wrong) once I have these rough numbers I can than look towards the cam design to try match them.
Sorry this is so long.
Thanks for reading.
Puxley
Testing a complete new engine design cannot begin until the project is complete. Then everything will fail at once, or you will be unable to point the finger at one faulty component since they come in connected groups.
Consider instead an “apprenticeship” making replacement parts for an existing engine. Calculate everything you need to understand the existing engine design and parts specifications. Each component will be an analysis, design and fabrication job in it's own right. Mastering the skills necessary need only be done once. At every point you can swap out and test components.
Once you know what you are doing you will be in a position to design and make components for an improved engine. You might consider taking an existing two cylinder design and extending it to a four cylinder engine. Will you make your own pistons and rings or buy standard components ?
By progressively replacing old with new you will end up with a complete handmade engine.
https://en.wikipedia.org/wiki/Ship_of_Theseus
Likes anorlunda
No the Pistons and rings will be from a company that had them built for these bikes especially. I will be doing the machining of the ends of the new crank, the barrels the decking, and the head work, I mainly want to do the calculations to get a better understanding of how everything relates to each other, I have full confidence in everything except the head where the Calcs will be more for fun as I won't get any real world application until it's on a flow bench, thank you for your reply
According to the https://www.amazon.com/dp/0837603331/?tag=pfamazon01-20, p. 406, «The highest volumetric efficiency values are achieved at mean gas velocities of 90 ... 110 m/s (empirical values).»
The mean gas velocity is defined as ##v_g = 2ns\frac{d^2}{d_v^2}## where ##n## is the rpm, ##s## is the stroke, ##d## is the bore and ##d_v## is the valve diameter.
Awsome thanks for the info!
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
