How can I solve the sum of this series without differentiation?
  • Thread starter Thread starter jamjar
    Series Sum
The discussion revolves around finding the sum of the series ∑_{k=0}^{n-1} kr^k without using differentiation. Participants suggest exploring the relationship to geometric series and consider operations that could transform the terms to resemble kr^k. Differentiation of the geometric series is proposed as a potential method, although some express concern about its appropriateness for pre-calculus. An alternative approach is introduced, involving rewriting the series as a double sum and swapping the order of summation. The conversation emphasizes that there are multiple strategies to solve the problem without resorting to differentiation.
jamjar
Hi,
I've come across this series and I'm not sure in which direction I should be looking to get an equation for the sum. I've tried some simple methods but have come up blank.
\sum\limits_{n = 0}^{n - 1} {nr^n }
Can anyone give me a nudge in the right direction?
Does it look like another series you know? Can you find some way to relate the two?
BTW: Your index is n, but you are summing to n-1. So n is doing double duty. I suppose you mean:
\sum_{k=0}^{n-1}kr^k
Perhaps the geometric series?
I can't see how to relate the two.
The extra multiplication by k is making it difficult.
Okay, here's where my ignorance about the contents of a pre-calculus class may come into play, but...the terms in the geometric series have r^k. Is there anything, some operation, you can do to each of the r^k terms to make it look like more or less kr^k?
hmmmmmmmmmmmm
I could differentiate perhaps?
I'm not sure what operations I can use within the summation.
That's a good idea!
What'd you get if you differentiate a geometric sum?
Well, I worked it out from there.
I just wasn't expecting to get any differentiation in pre-calc.
Thanks for the help :smile:
You can do it without differentiation if you like. Write it as a double sum and swap order of summation. You could also think of this as writing it as a sum of geometric series (all of different lengths).
