How can I use a radio wave to turn on/off a siren?
To turn a siren on and off using radio waves, a low-power radio transmitter circuit can be designed, but it has a limited range of 10m-20m and requires tuning to an open frequency, which can be challenging in crowded areas. A suggested approach is to use a cheap radio receiver that can detect a specific tone frequency from the transmitter. Alternatively, using an infrared (IR) link or a garage door opener system is recommended, as these provide a more secure method with coded signals for activation. Wireless modules from companies like Link Technologies can be utilized to connect a relay for switching the siren. This method enhances security and reduces the risk of hacking.
Harmony
How can I use radio wave to turn on/off a siren? I think it is possible for me to design a radio signal through this schematic:
http://www.aaroncake.net/circuits/fmtrans.htm
The problem is, how do I design a receiver that can switch on a siren by receiving the radio signal?
You could use a cheap radio receiver, and just bandpass the audio output to look for the tone frequency that you would be transmitting.
The circuit you show is for a typical low-power, unlicensed radio transmitter. The range of these transmitters is about 10m-20m, so don't expect too much. You also have to tune them to an open station frequency, so if you are in a highly-populated area with lots of FM radio stations, you will have trouble finding an open frequency.
You might consider using an IR link instead of FM. You could start with a kit, like the one in the lower right corner of this page:
http://www.transeltech.com/kits/kits1.html
Try a garage door opener system
Try using a garage door opener system.
Two reasons.
1-you need a transmitter on a set frequency that trans mits a code
2-you need a receiver that receives a set frequency that needs a code to turn the power on.
Instead of the door opening and closing you could have the sireen latch on or off and the security of any hacker reduced.
good luck
you would get ready wireless modules from Link Technologies they make ready modules you can further connect a buffer relay to switch on / off the siren
Rick
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
