How can ice cool an alcoholic drink below 0°C?
  • Context: High School
  • Thread starter Thread starter stinsonbr
    Cool Ice
The discussion centers around the phenomenon of how ice can cool an alcoholic drink to below 0°C. Participants explore the factors involved, including the temperatures of the ice and drink, the concept of equilibrium temperature, and the implications of freezing point depression. The scope includes theoretical reasoning and conceptual clarification related to thermodynamics and phase changes.
  • Some participants inquire about the temperature of the ice and its role in cooling the drink below 0°C.
  • There is a suggestion that the equilibrium temperature reached between the ice and drink depends on their initial temperatures and masses, with some arguing that the drink could reach a temperature below the ice's initial temperature.
  • One participant mentions the concept of freezing point depression as a relevant factor in the cooling process.
  • Another participant challenges the idea that the drink can cool below the ice's temperature, asserting that heat exchange will stop once both substances reach the same temperature.
  • There is a discussion about the melting of ice and whether the remaining ice can become colder as it melts, with differing views on the implications of this process.
  • Some participants propose that the final temperature can be below the initial temperatures of both the ice and the drink, depending on the freezing point of the liquid.
  • One participant introduces the idea of using dry ice and pressure as potential factors in cooling the drink.
  • Several participants express confusion about the thermodynamic principles at play, with requests for simpler explanations of the concepts involved.
Participants do not reach a consensus on whether the drink can cool below the ice's initial temperature. Multiple competing views remain regarding the thermodynamic principles and the effects of freezing point depression.
Some participants note the complexity of the interactions between different phases and substances, suggesting that the discussion may depend on specific conditions and definitions that are not fully resolved.
  • #31
In the real world, the glass is empty and being refilled long before that.
Science news on Phys.org
  • #32
ToddSformo said:
How about this: freezing is exothermic reaction, latent heat is given off. Melting is an endothermic reaction. So when ice is added to alcohol, it takes energy to melt the ice, and the energy comes from the liquid, in the form of heat, which, in turn, lowers the temperature of the ice-alcohol system?
Correct.
  • #33
mfb said:
If the temperature is below zero, no melting happens.
If both start below zero, yes.
You cannot reach an equilibrium temperature below zero if ice melts (neglecting transient effects from finite heat conductivity and so on)
That remains the main issue of the thread and it is not correct.
That, again, is why I think it is a bad idea to expand the scope - I didn't even realize we were still in disagreement about the main issue!
I'll be clear:
If you add ice at 0C to a liquid which is at 10C, but has a freezing point of -5C, the final mixture will be both at about -5C (ignoring dilution).
Heck (the ice cream making example), you can even start with a water/ice mixture at 0C, dump a bunch of salt in, stir, and the temperature will drop.
http://www.thekitchn.com/freezing-science-the-role-of-s-124357
  • #34
The general assumption that needs to be made is that the masses of the ice and the drink, and the temperatures of the ice and drink, are not so extreme, so that the final system is in an equilibrium between solid and liquid states. People are making the obvious statements that a kilogram of ice, cooled to absolute zero, will freeze a small drink to some very low temperature, or a small ice cube at exactly the freezing point, in a large warm drink, will end up with a large, slightly less warm drink. Let's ignore those situations ... it is important to note that an adequate amount of ice is needed, and an adequate amount of ordinary drink ... but the ordinary drink preparation sort of assumes those.
So in that ordinary drink, the liquid phase is some solution of alcohol, solutes and water. The freezing point of a solution is below 0-degrees-C. Freezing point depression, as pointed out repeatedly. The ice is at a freezer temperature, about -20-degrees-C. The ice mass, and the phase change of melting ice provide a heat sink for some of the heat in the drink-solution. The ice cools the drink, warming the ice, and melting some ice, turning it into water which dilutes the drink. At equilibrium, the drink is at the freezing point for that particular solution, which is below 0-degrees-C. The mass of ice is also at that same temperature. The temperature will not increase, while there is ice mass remaining that can be warmed, absorbing heat in the warming process. The phase change of ice to water is also a potent heat sink. And the solution around that ice is acting just like adding salt onto a snowy driveway ...
At the equilibrium temperature, the surface of the ice cube is both melting and freezing at the same rate. The interior of the ice cube, which is protected by the surface, still contains pure water, which is below the freezing point for that water. The drink-solution will not decrease further in temperature, as at its freezing point it remains at constant temperature, while the heat of fusion is removed. The ice cube will not increase in temperature, as it is in temperature equilibrium with the surrounding drink-solution.
If it helps, think of dropping cold, steel balls at -20-degrees-C into a drink. The balls will warm and the drink-solution will cool. The drink-solution can only cool to the freezing point of the solution. At that point frozen solution begins to accumulate on the balls.
There are some drinks that contain so much sugar or alcohol that they will not freeze at -20-degrees-C. In those cases, the temperature will simply be the result of the heat capacities of the solution and the solid.
  • #35
Salt on a snowy road is another example: the salt does not warm the snow up to 0C, it makes the plain snow melt at below 0C.
The mechanism may be confusing: how does the snowy road know it is salt and not gravel sitting on it if they are separate? Just like with evaporation, there is a distribution of energy, where molecules spontaneously exit and re-enter the solid. When they exit, they mix with the salt and can't re-freeze. This lowers the average kinetic energy (temperature) of the molecules in the ice. Repeat until equilibrium is reached or all of the ice is gone.
  • #36
russ_watters said:
Keeping within the narrow question, the interesting/difficult/counterintuitive behavior is that both the ice and drink can cool down when you combine them if both start above the freezing point of the drink.
Only if you take things like cooling from mixing into account, and even then I did not see a convincing situation yet that would prove this. If you do not (e.g. separate ice and drink by a thin plastic sheet), this is not possible. Heat will flow from the warmer to the colder object, heating the colder object.
  • #37
I'm not certain what you mean by "cooling from mixing", but yes, if you wrap the ice in plastic it will not be able to go into solution with the drink when it melts, producing different results. For example, if the ice starts at 0C and the drink above 0C, it will have an equilibrium at 0C (assuming sufficient ice).
  • #38
I think he means positive enthalpy of mixing.
Why should no dilution produce different result than ignoring dilution (as assumed in your post #33)?
  • #39
russ_watters said:
A five year-old doesn't have much chance here, but I'll try to be basic...
This isn't like mixing two liquids together - the concept of an equilibrium temperature somewhere in between doesn't apply. A liquid freezes or a solid melts at one and only one temperature (per a given substance and pressure). If you add heat to ice (put it in a warmer liquid) it will melt at its melting temperature, period. If you remove heat from water, it will freeze at its freezing temperature, period. If those are different temperatures, the lower temperature wins because while the ice can exist as ice at a lower temperature than its freezing point, you can't remove heat from a liquid (by making it melt ice) without dropping its temperature.
This may seem like a bit of a contradiction, but it is actually somewhat similar to the simpler case of a liquid at its boiling point. There is only one boiling point at a given pressure and no matter how much heat you add, that won't change. Conversely, if you lower the pressure above a liquid (say, put it in a vacuum chamber), it will start to boil and that will lower the temperature to get it to the new boiling point.
Phase changes are isothermal and are either exo or endothermic. Water freezes at 0oC. Which is an endothermic process. The more heat you remove doesn't effect temperature of the phase change, but it does hasten the kinetics. Same as boiling water at 100oC, the more heat you put in, the faster the water boils, but never exceeds 100oC. Somebody mentioned freezing point depression. Mixtures of substances will have lowered freezing points, and elevated boiling points.
  • #40
In what possible scenario would they both cool down? Assuming you wouldn't put them both in a deep-freezer...
  • #41
I'm not referring to dilution there, I'm referring to the existence of the solution (or not) in contact with the ice.
  • #42
I gave an explicit example above:
  • #43
You're looking at the scenario backwards: when ice melts, the act of melting removes heat and reduces the temperature of the remaining ice.
In our example, heat transfer between the ice and drink combined with the absorbed latent heat of melting result in a lower final temperature.
  • #44
When all the liquid is at zero degrees, what will make the temperature drop more?
  • #45
The latent heat absorbed by the melting ice.
  • #46
While I'm stil not certain we're all talking about the same issue/scenario, it appears to me that there is general disagreement with my explanation/understanding of how this works. So I propose an experiment (which I will do and video tonight):
1. Take an insulated travel mug and fill it 3/4 with ice from my freezer.
2. Fill it further with cold water from my tap, so the ice is just floating. Cover and shake.
3. Measure and record the temperature (with a calibrated RTD probe).
4. Add 1/4 cup (60g) of table salt. Cover and shake.
5. Measure and record the temperature.
My freezer is colder than it needs to be, but not absurdly cold. I'll measure it, but I would guess around -10C. My tap water will vary depending on how long I leave it running, but likely between 10C and 15C. My tap water is very hard, but I use a softener and filter. This will probably leave some dissolved ions in it.
So:
What will the temperature be before and after adding the salt?
  • #47
Without dilution the minimum temperature is 0 °C.
That's where the dilution comes into play. NaCl has a positive enthalpy of solution and reduces the freezing point of water. Without these effects the temperature cannot drop below 0 °C. As ethanol has a negative enthalpy of solution (according to http://sites.chem.colostate.edu/diverdi/C477/experiments/isothermal%20microcalorimetry/references/j_mol_struct_1993_v300_p539.pdf) that won't work with alcoholic drinks.
  • #48
I see it now. Yes, that could be true. The melting of the ice takes heat from it's surroundings, the remaining ice or the liquid. Latent heat is a tricky thing.
  • #49
I think we are using the word "dilution" to refer to different things and the way I designed the experiment may have an impact there. When I say "dilution" I am referring to a change in the concentration of the liquid solution as the ice melts. In cases where the amount of melting ice is small compared to the amount of water, there is very little change in the concentration of the solution and hence very little change in the melting point of that solution. That's what I was referring to when I said I was ignoring dilution.
You are referring to enthalphy of dissolving the solute, which I inadvertently brought into the situation by saying I'd add the salt after the ice and water are mixed. We can go back to the original formulation, which is the ice being added to the solution if that is helpful. Either way, the enthalpy of solution should not come into play here. The main reason I did it is that I wanted to demonstrate that both the ice and water can drop in temperature and that is harder to do if they aren't already stable at 0C.
I'll restate my point/undertanding though: whether we're talking about alcohol or water/salt, the melting of the ice can provide the energy required to cool the liquid below 0C even if both start above 0C.
I'll have to concede though that I had not considered that water and alcohol might behave differently in such a test...
  • #50
I'
I'm not sure if I understand this: correctly: " Water freezes at 0oC. Which is an endothermic process." Freezing (liquid to solid phase change is an exothermic process), while melting is endothermic. Please correct me if I'm wrong.
  • #51
No ice will melt if both ice and drink are at 0 C, at least if we keep ice and drink separate the ice melting and freezing is in equilibrium. Mixing changes that, but there we are back to the mixing thing...
  • #52
russ_watters said:
Actually, that isn't true(you aren't the only one who said it...): they meet at the freezing temperature of the liquid, regardless of either's starting temperature.
So that means, counter-intuitively, that they can end up colder than either started.
So the only thing that matters here is the freezing temp of the drink (as long as you add enough ice to reach it).
I think you're mistaken.
The temp will always be at some intermediate value at homeostasis. This is not evaporative cooling. A state change will extract heat/energy without a change in temp but that heat can only move to a substance of lower temperature.
The correct answer to the question is 1) ice may be at any temperature below 0 and b) mixing EtOH with water results in a mixture with a lower freezing point than water.
  • #53
Ok, new experiment, designed to avoid the issue of the dissolving enthalpy and the issue of dilution as the ice melts. Also, we'll test both water/alcohol and water/salt:
Setup #1: 100 mL of water mixed with 50g of salt
Setup #2: 100 mL of Southern Comfort (50% alcohol by volume)
1. Refrigerate all components of the experiment. Ice is equalizing in an insulated ice bucket in the fridge as well.
2. Measure and record temperatures of both liquids.
3. Add ice to each.
4. Measure and record temperatures again.
At the start, the ice should be right at 0C and the water and alcohol should each be at a few degrees C. What happens when I add the ice?
  • #54
In a real drink and in both of the experiments I propose, there will be mixing -- so, what happens to the temperature of the mixtures?
  • #55
3. Add ice to each.
Test completed. Results:
Starting ice temp: about 0C
Starting Water/Salt Temp: 4.6C
Starting SoCo Temp: 5.0C
7 min Water/Salt Temp: -6.1C
7 min SoCo Temp: -7.6C
Incidentally, now after about 25 minutes, the temperatures are about the same, but the ice in the SoCo is noticeably more melted. You can probably tell, but that's probably because the green mug is substantially lower quality than the black one. Photo after 7 min and 3 videos:
  • #56
Nice experiment. Mixing is a key ingredient here. Would you be willing to redo the experiment with the ice kept in plastic bags?
  • #57
Sure - though I am in agreement with mfb about what the result will be, and it is also a different experiment from what the OP was asking about.
I was wrong about one thing: The freezing point of 50% alcohol is -52C (I didn't look that up ahead of time) and with a starting point 57C higher and a poorly insulated mug, melting and dilution of the alcohol was a significant factor in the final temperature of the mix. The result was a substantial amount of melting and dilution and thus an equilibrium temperature that was not predictable (though I actually didn't try to predict in anyway beyond whether it would be above or below 0C). I may try that part of the experiment again as well, with ice and alcohol in my freezer. I'll by trying to get ice to melt at -20C or lower (as it does on a road when you add salt) and achieve a lower temperature than my freezer.
Note, the key result here was what several people said outright or implied could not happen: the mixture ended up at a temperature lower than either constituent started and lower than 0C.
  • #58
Yes. It seems clear that the heat of mixing effect, resulting from melting of ice to form pure water which then mixes with the water/alcohol solution to yield an accompanying heat of mixing, is key to this phenomenon. The excess heat of mixing HE of alcohol and water is known experimentally as a function of temperature and mole fraction, and this can be used to predict the final temperature, assuming that the system is adiabatic. However, I doubt that this calculation will yield a final temperature anywhere close to the freezing point of the initial (or even the final) water/alcohol mixture.
Chet
  • #59
Chet
No, I don't think so. The heat of fusion of ice is an order of magnitude larger than the mixing enthalpy and as someone else pointed out, the mixing enthalpies of the two example solutions go in opposite directions.
  • #60
I need to make a correction:
mfb said:
If ice and drink are at -2C for example, they are in thermal equilibrium (by definition of temperatures). Nothing melts or freezes, assuming the alcohol content is sufficient.
russ_watters said:
Agreed, and in the real world that can happen since sometimes people keep their alcohol in the same freezer as their ice. The wording of the question in the title implies that isn't the starting condition.
I let myself be led astray here: this is false.
Yes, it is counter-intuitive to say that ice in a drink is not at thermal equilibrium if both are at -2C, but it is true. In the experiment I did last night, the ice/alcohol mixture passed -2C on its way to an equilibrium temperature of about -8C.
The issue is in how temperature is defined and works. In many problems it is acceptable to assume that the temperature of a subtance is completely uniform, when in reality it is not: it is a bell-curve, centered around its average value, caused by atoms vibrating randomly against each other. In this case, the bell curve matters because that is what is driving the process being investigated.
When ice is at -2C, not all of it is at -2C. Some is at -10C, some at 0C. Some molecules gain enough energy to pop out of the solid and into the liquid. When that happens, energy is removed from the ice (via the latent heat of fusion), lowering its temperature. This is the mechanism that causes two substances that are both at -2C to spontaneously get colder.
I'll demonstrate this tonight as well. It was specifically mentioned earlier that some people keep their aclohol in the freezer. Based on my results from last night, if I take ice and alcohol from a freezer (at about -15C if I remember correctly) and mix them together, I will achieve a temperature perhaps as low as -30C.
The other specific case mentioned by the OP was room temperature alcohol mixed with ice at 0C. I'll try that as well. The result will again be a mixture a little below 0C.
  • · Replies 21 ·
  • · Replies 25 ·
  • · Replies 17 ·
  • · Replies 32 ·
