How can it possibly be raining outside
  • Thread starter Thread starter mrspeedybob
    Outside
Humidity readings can be confusing, especially when precipitation occurs at lower relative humidity levels. A humidity meter reading of 57% does not necessarily indicate that condensation cannot happen. Precipitation often initiates at higher elevations where relative humidity can be significantly different from surface levels. It's common for rainstorms to occur with an average relative humidity around 85%, even when local readings are below 100%. The idea that condensation only occurs at 100% relative humidity is an oversimplification. If precipitation is observed while the hygrometer reads 57%, it may require recalibration or replacement.
mrspeedybob
when the humidity meter on my back porch reads 57%? May be a silly question but I don't know. I thought when the humidity exceeded 100% the excess moisture condensed out of the air and that's what we call precipitation. Obviously either my meter or my understanding is faulty?
Or both. Condensation may happen high up, where the temperature is much lower. When water falls down it may have no time to get warm enough and to vaporize before hitting the ground.
+1 Condensation happens in the clouds at lower temperatures and there the relative humidity is 100% (or more). If your humidity meter is reading 100%, it would most likely be foggy.
Thanks guys.
If you are getting precipitation when your hygrometer only reads 57%, then your hygrometer either needs re-calibration or replacement.
However, the vast majority of precipitation events occur when the RH in the surface layer (lowest 100 m) is less than 100%. This is because of the abundance of hygroscopic particles in this lower layer. The average RH during rainstorms is usually around 85%. As Borek pointed out, most precipitation is initiated a higher elevations where the RH may be significantly different from that at the surface.
The notion that condensation always occurs when the RH reaches 100% (and not until) is widely taught in primary schools, but is simplistic and often just dead wrong.
Thread 'The Secrets of Prof. Verschure's Rosetta Stones'
(Edit: since the thread title was changed, this first sentence is too cryptic: the original title referred to a Tool song....) Besides being a favorite song by a favorite band, the thread title is a straightforward play on words. This summer, as a present to myself for being promoted, I purchased a collection of thin sections that I believe comprise the research materials of Prof. Rob Verschure, who at the time was faculty in the Geological Institute in Amsterdam. What changed this...
These last days, there is a seemingly endless cluster of rather powerful earthquakes close to the islands of Santorini, Amorgos, Anafi, and Ios. Remember, this is a highly volcanically active region, Santorini especially being famous for the supervolcanic eruption which is conjectured to have led to the decline of the Minoan civilization: https://en.m.wikipedia.org/wiki/Minoan_eruption To grasp the scale of what is happening, between the 26th of January and the 9th of February, 12000...
