How Can Op-Amps and Switches Create a Multi-Output Voltage Circuit?
  • Thread starter Thread starter gigo_gigo88
    Design Opamp
This discussion focuses on designing a multi-output voltage circuit using operational amplifiers (op-amps), resistors, and switches. The circuit aims to convert a fixed 5V DC input into selectable output voltages of -1V, -2V, -4V, -8V, and -16V. Participants recommend using the inverting amplifier configuration to achieve the desired outputs by selecting appropriate resistor values and employing switches to create different resistor combinations. Simulation results using Multisim indicate successful voltage outputs, but challenges remain in connecting the circuits together.
  • Understanding of inverting amplifier configuration
  • Knowledge of resistor value calculations for desired output voltages
  • Familiarity with switch configurations for circuit design
  • Experience with circuit simulation tools like Multisim
  • Research inverting amplifier design principles and calculations
  • Explore resistor value selection for specific voltage outputs
  • Learn about switch configurations for combining multiple outputs
  • Practice circuit simulation using Multisim for complex designs
Electronics engineers, circuit designers, and students interested in operational amplifier applications and voltage regulation techniques.
gigo_gigo88
helllo i am having a problem designing this circuit i should use opamps resistors and switched
i have a fixed 5v dc input i should get an outpout of -1 -2 -4 -8 -16 the user should choose which one he should use can i get some help please?
Look up the inverting amplifier configuation. Then figure out which resistor values will give you each desired output. Then figure out how to use switches to generate the different resistor combinations.
hii and thank you i simulated this circuit on multisim the first one on the left gives vout across the resistor 1v and the other circuit multiplies it by 2
by the problem i am having is connecting them together
  • · Replies 44 ·
  • · Replies 21 ·
