How can someone prove the following trigonometric identity?
cocopops12
it's bothering my brain..i thought about it many times...i can't make intuition of it
can anyone prove it?
oh by the way... C = Sqrt[A^2 + B^2] and theta is equal to arctan(B/A)
Mathematics news on Phys.org
Hey cocopops12 and welcome to the forums.
The easiest way IMO is to use geometry.
Think about for example right angled triangle with the hypotenuse coordinates (Bsin(wt),Acos(wt)).
Now think about the angles and sides involved where in your RHT, you have (Acos(wt))^2 + (Bsin(wt))^2 = hypotenuse.
Perhaps you could use the angle-difference-identity of the cosine?
See: http://en.wikipedia.org/wiki/Trig_identities#Angle_sum_and_difference_identities
That is: ##\cos(ωt-θ)=\cos(ωt)\cos(θ) + \sin(ωt)\sin(θ)##.
@chiro: I don't understand how your triangle would work out...
However, I can think of different triangles that would fit.
You can draw 3 rectangular triangles with sides (A,B,√(A2+B2)), (Acos(ωt),Asin(ωt),A), and (Bcos(ωt),Bsin(ωt),B).
In the proper configuration these 3 triangles show the result.
Yeah that would be optimal.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
I'm interested to know whether the equation $$1 = 2 - \frac{1}{2 - \frac{1}{2 - \cdots}}$$ is true or not. It can be shown easily that if the continued fraction converges, it cannot converge to anything else than 1. It seems that if the continued fraction converges, the convergence is very slow. The apparent slowness of the convergence makes it difficult to estimate the presence of true convergence numerically. At the moment I don't know whether this converges or not.
