How can you find the Fourier series of Sin[x] with a period other than 2n Pi?
The discussion revolves around finding the Fourier series of the function sin(x) when the period is not equal to 2nπ. Participants explore the implications of different periods on the Fourier series representation and the calculations involved.
  • Technical explanation, Debate/contested, Mathematical reasoning
  • One participant asserts that the Fourier series of sin(x) is simply sin(x), comparing it to the Taylor series of a polynomial.
  • Another participant questions this by stating that if all Fourier coefficients (ao, an, bn) go to zero, the resulting series would also be zero, which raises concerns about the validity of the method.
  • A participant points out that the b1 term does not go to zero, indicating that sin(x) should remain in the series.
  • There is a discussion about the calculation of bn coefficients, with one participant noting that for n=1, the integral of sin^2(x) over the interval from -π to π is not zero.
  • Another participant confirms that for bn where n is not equal to 1, the coefficients are indeed zero.
  • A later reply emphasizes that while the Fourier series of sin(x) with L = 2nπ is sin(x), for other periods, the series representation differs significantly, providing a specific example of terms in the series for a different period.
  • The participant mentions that the initial terms of the Fourier series for sin(x) with a different period are calculated using Mathematica, although they acknowledge some inaccuracies in the results.
Participants do not reach a consensus on the Fourier series representation of sin(x) for periods other than 2nπ, with multiple competing views and calculations presented throughout the discussion.
There are unresolved mathematical steps regarding the calculation of Fourier coefficients and the implications of different periods on the series representation. The discussion reflects varying interpretations of the Fourier series based on the chosen period.
misterme09
I know it's trivial...but how do you find the Fourier series of sin(x) itself? I seem to get everything going to zero...
You should. The Fourier series of sin(x) is simply sin(x). This is like asking what the Taylor series of y=x^2 is.
Yes, but if the Fourier series of f(x) = ao/2 + sum over n from 1 to infinity (an*cos(n*x) + bn*sin(nx)) then if ao, an, and bn go to zero, you are left with simply zero as the Fourier series. Shouldn't this method still work?
What ever makes you think all of the terms go to zero? One term does not, the b1 term. You end up with sin(x).
bn = (1/pi) int ( sin(x) * sin(n*x) dx) from -pi to pi becomes a multiple of sin (n*pi) which is always zero.
if n = 1, then it's the integral of sin^2x, which is certainly not zero over -pi to pi.
That's true. Okay, but for bn where n isn't 1, bn is zero, correct?
Correct
Sorry to gravedig, but considering this is the first result for the Fourier series of sin[x]. I had to correct it.
A Fourier series is a series that has a period equal to part of a qualified f(x) from -L to L or 0 to 2l.
Yes, the Fourier series of Sin[x] with L = 2n Pi where n is an element of Z is simply Sin[x].
But the Fourier series of Sin[x] with L =/= 2n Pi is NOT Sin[x].
Look at the graph of Sin[x] from 0 to Pi/2. If you wanted a function that repeated that period, Sin[x] would no-where near work.
The first few terms of that Fourier series would be: (4 Cos[1/2] Sin[x])/(-1 + \[Pi]^2) + (
8 Cos[1] Sin[2 x])/(-4 + \[Pi]^2) + (
12 Cos[3/2] Sin[3 x])/(-9 + \[Pi]^2)
According to mathematica. (It's slightly incorrect, since the outcome of the periods are off. Working on it)
  • · Replies 33 ·
  • · Replies 23 ·
