How check for subspaces in Linear Algebra?
To determine if the set of vectors in the form (2x+3y, x, 0, -x+2y) is a subspace of R^4, it is essential to verify closure under addition and scalar multiplication using algebraic methods rather than random values for x and y. The sum of two generic members of the set remains in the same form, confirming closure under addition. Similarly, multiplying a member by a scalar also results in a vector of the same form, establishing closure under scalar multiplication. A basis can be derived from the vectors (2, 1, 0, -1) and (3, 0, 0, 2), which span the subspace. Understanding the relationship between x" and y" in the context of these operations is crucial for confirming the subspace's properties.
saintdick
consider R^4. Let V be the set of vectors in the form ( 2x+3y, x, 0 , -x+2x) is this a subspace
of R^4 and why? find a basis if it's possible
I know that the set must work under scalar multiplication and vector addition but i am confused here because of the variables. how do you actually test that? do you just choose random values for x and y?
for the second part, i know that a basis could be found if it's a subspace but i am not sure how to find it?
IF you believe 'closure' of addition and scalar multiplication is false, yes, you could look for values of x and y which make the statement untrue. That is, look for a "counter-example".
However, if it is really a subspace, closure of addition and scalar multiplication must be true for all x and no matter examples you tried, that would never prove it true for all.
Instead use algebraic theorems to show the set is closed under addition and scalar multiplication. For this paraticular example, two "generic" members of the set would be of the form (2x+ 3y, x, 0, -x+ 2y) and (2x'+ 3y', x', 0, -x'+ 2y'). The sum of those is ((2x+ 3y)+(2x'+ 3y'), x+ x', 0+ 0, (-x+ 2y)+ (-x'+ 2y'))= (2(x+x')+ 3(y+ y'), x+x', 0, -(x+ x')+ 2(y+ y')). Do you see that this is in the same subset? It must be of the form (2x"+ 3y", x", 0, -x"+ 2y"). What are x" and y" in this case?
To see that it is closed under scalar multiplication, take a general member of the set, (2x+ 3y, x, 0, -x+ 2y) and multiply by the scalar "r":
(r(2x+ 3y), rx, r0, r(-x+ 2y))= (2(rx)+ 3(ry), rx, 0, -(rx)+ 2(ry)).
Again, do you see that is of the form (2x"+ 3y", x", 0, -x"+ 2y")? What are x" and y" here?
To find a basis, note that any member of this set is of the form (2x+ 3y, x, 0, -x+ 2y)= (2x, x, 0, -x)+ (3y, 0, 0, 2y)= x(2, 1, 0, -1)+ y(3, 0, 0, 2).
Thanks for your reply, but i am still confused? what to do you mean when you ask " What are x" and y" in this case". So let me get this straight, when you prove it the way you did, as long as the form doesn't change then that means it's a subset. For the basis, are both of those columns form one basis or do each one form a single basis?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
