How do adapters work? (SATA to USB, or VGA to HDMI)
Adapters like SATA to USB or VGA to HDMI can function through a combination of electronic circuits and, in some cases, embedded software. Some adapters are straightforward rewiring solutions, while others act as protocol converters that require additional processing. For example, USB to Cat 5 Ethernet is a simple rewire, whereas SATA to USB 3.0 involves more complex conversion processes. It's important to note that certain adapters only work in one direction, such as USB to SATA, which does not reverse to SATA to USB. HDMI, being a digital output, can be converted to VGA's analog signal, but not the other way around. Typically, the conversion processes in these interfaces are handled by hardware rather than software, although some may include firmware for specific functions like power management and data flow synchronization.
emh01
Does adapters (exp: SATA to USB or VGA to hdmi) work with special softwares for conversion or are they only electronic circuits which gets and directs input signals to correct output pins?
Computer science news on Phys.org
Answering to match the specificity of your question, often elements of both.
Likes Rive, sysprog, Vanadium 50 and 1 other person
In addition to what @Asymptotic said: some adapters are simple rewirings, and others are protocol converters that require intermediary processing. An example of the former is USB 2.0 ##\leftrightarrow## Cat 5 Ethernet cable; an example of the latter is SATA ##\leftrightarrow## USB 3.0.
243269
Likes emh01, anorlunda and Asymptotic
Some of hese only workone way also. You can get USB to SATA interfaces but it doesn't work the other way around. Likewise HDMI is going to be a digital output, VGA is analogue. You can convert a HDMI signal to an analogue one but you cannot get a VGA to HMDI convertor.
I think you can... And while SATA to general USB won't be found, I wouldn't be suprised to find some pendrive-on-sata type frankenboard, since it is already not a problem to fit some SD-cards into a raid hanging on SATA 😉
USB and SATA are both bidirectional. You can get interfaces to do whatever you want with either of their protocols. Single-chip analog to digital converters, and digital to analog converters, are common components. VGA to HDMI convertors are easily available.
sysprog said:
In addition to what @Asymptotic said: some adapters are simple rewirings, and others are protocol converters that require intermediary processing. An example of the former is USB 2.0 ##\leftrightarrow## Cat 5 Ethernet cable; an example of the latter is SATA ##\leftrightarrow## USB 3.0.View attachment 243269
in latter example does it use embeded software or only does this with special circuits?
I assume you're referring to the SATA ##\leftrightarrow## USB 3.0 interface. Typically, none of that would be done at the software level, but some of it might be done as one-time ROM firmware. I don't know the specifics of any particular such device, but you can see from the following image that it does power handling and 'mapping' one set of pins to another, with some small IC chips to manage the bidirectional data flow with conversion, synchronization, and throughput assurance.
Likes emh01
