How Aeroplanes Fly: Deriving Equation For Lift Force
  • Thread starter Thread starter billy92
The discussion focuses on understanding the lift force equation for airplanes, specifically the equation 1/2 ρv²AC_L. Participants clarify that this equation represents the relationship between lift, dynamic pressure, wing area, and the coefficient of lift (C_L), which is influenced by wing shape and airflow. The derivation of C_L is linked to lift force and is affected by various factors, including angle of attack and Reynolds number. Additionally, resources like polar charts and software such as XFOIL are suggested for further exploration of lift equations. Understanding these concepts is essential for accurately describing how airplanes achieve flight.
billy92
I am currently looking into how aeroplanes fly for a report which i am writing.
I understand the theory behind the lift force produced by different pressures above and below the wing. However, i need to use equations which i can show how to derive in the report.
I have found the following equation \frac{1}{2}ρv^{2}AC_{L} but i am not sure how to derive this equation.
Thanks
If you understand the mechanism by which the aeroplanes fly, understanding this equation is not a very difficult task. First of all, you must realize that this equation only describes the proportional relationship between different factors affecting the lift.
As you pointed out, Lift is produced due to pressure difference on the upper and lower surface of the wing.
Lift (Force) = Aera X Pressure.
The term 1/2 ρ v^2 is the dynamic pressure, which can be thought of as the pressure (rather fall in pressure) due to movement of air over the wing (remember bernoolli's equation: P + 1/2 ρ v^2 = constant). Then you have the area (S) of the wing.
The last term, Cl is basically the proportionality constant which depends only on the shape and the cross-section (airfoil) of the wing. It basically depends on the way the wing redirects the flow to produce lift. So you will have the same Cl for a particular aircraft flying at different speeds or even if the aircraft is scaled down.
Thanks for the reply. I am fine with most of the theory behind it its just the derivations and formulas that I am a little stuck on.
Im still not entirely sure how to derive the equation i stated. Also is it this equaion which best describes lift as I've found others which also explain lift in slightly different ways.
It's not derived, it's a rearrangement of the equation used to define CL
C_L = \displaystyle \frac {L} {\frac{1}{2}ρv^{2}A}
where L is lift force.
In the real world CL is a complex function of angle of attack, velocity, air parameters and wing parameters. Normally velocity, air parameters and the chord length of a wing are combined to create a term called Reynolds number:
http://en.wikipedia.org/wiki/Reynolds_number
2d charts called "polars" for airfoils will show one or more curves for CL versus angle of attack, Cd (coefficient of drag) versus angle of attack, and/or CL versus Cd, with separate curves based on Reynolds Number, like RE = 10^5, RE = 10^6, ...
http://www.davincitechnologies.com/AOTour5.htm
Programs used to generate these polar charts use some simplified version of Navier Stokes equations. XFOIL is a freeware version of this type of program:
http://web.mit.edu/drela/Public/web/xfoil
Thanks for the reply. Makes a bit more sense. Is the equation for the coefficient of lift derived from anything?
Also is there any other equations for lift which i should be looking in to?
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
