kewlkilla said:
hi
i'm doing a physics project on centrifuges (how they work+applications of centrifuges)
I understand what the centrifugal force is but why do the more dense particles get pushed to the end of the test tube? since the test tube is on its side gravity shouldn't have to do anythin with it. and why do the less dense particles end up being near the top of the tube.
also could you help me with applications of centrifuges(medical, forensic, industrial, training humans)---perhaps some good links, because I've been having a really hard time, and wikipedia's page was disappointing
appreciate any help
thanks
Gravity has something to do with the action of a centrgifuge, but the reason for spinning the test tubes is to create an environment where the separating action on the particles is the same as it would be if you could significantly increases the force of gravity. So first you want to understand why the denser particles would go to the bottom and less dense particles to the top, and then understand how a centrifuge amplifies the effect.
A few forces are at work when an object is in a fluid. A couple of them come from gravity, and one comes from the viscosity of the fluid. Gravity attracts an object toward the center of the earth. This includes the molecules of a fluid, and causes an increase in the pressure of a fluid as you move closer to the Earth's center. The result of gravity and the action of a fluid on a stationary object is a force that we often call the "apparent weight" of an object. It is the combination of gravity acting downward and the buoyant force acting upward. The force of gravity is proportional to the mass of an object, while (for a submerged object) the buoyant force is proportional to the volume of the object. Consequently, the net force (apparent weight) on a dense object is a greater fraction of its weight than that of a less dense object. Furthermore, when an object moves through a fluid there is a force that resists the motion of the object that depends on the viscosity of the fluid and on the area the object presents to the fluid. This accentuates the difference between the apparent weight and true weight of an object moving through a fluid.
If you take a glass of water and pour in some dirt and shake it up, then let it settle, you find the more dense particles settling to the bottom of the glass more rapidly than the less dense particles because the net force per mass downward is greater for the denser particles. But it takes time for less dense particles to settle out, and for small particles whose density is not much greater than that of water, the time can be on the order of many hours to days. Some particles can remain "in suspension" indefinitely.
If you could turn up the force of gravity, you could speed up the settling process, and even cause some particles that might otherwise remain in suspension to settle out. The cenrifuge is a device that has the same effect on the mixture of fluid and solids that would result from increasing gravity, with the added advantage of increasing it more at the bottom of the tube than at the top. Although to an "inertial observer" the spinning centrifuge does not produce a "real force" it does increase the pressure within the fluid, and it produces a motion of the particles in suspension that causes them to move toward the bottom of the test tube by actually moving the bottom of the test tube toward the particles. To an observer "in the test tube" the effect is the same as increasing the gravitational force by an amount that increases with the speed of rotation of the mixture and radius. This additional "apparent force" is called the centrifugal force and it is greater at the "bottom" of the tube than it is at the "top". This means that once the particles start to separate as they would under the influence of constant gravity, the separation of denser particles from less dense particles is accentuated.
If you have time for your project, you might contact a centrifuge manufacturer and request information from them about how things work.
