How Do Equations Demonstrate Time Dilation Near Black Holes?
  • Context: Graduate
  • Thread starter Thread starter bunsen1
    Black hole Hole
The discussion centers around the mathematical demonstration of time dilation effects near black holes, exploring the equations and concepts related to gravitational time dilation. Participants examine the implications of these effects in various contexts, including comparisons with other gravitational fields and the behavior of clocks in different scenarios.
  • One participant seeks equations to demonstrate time dilation near black holes to convince a skeptic.
  • Another participant references a Wikipedia article on gravitational time dilation, noting that the effect occurs in any gravitational field, not exclusively near black holes.
  • A participant corrects a previous claim about the comparison of clock rates on the ISS and Earth's surface, explaining the complexities introduced by orbital velocity and altitude.
  • There is a discussion about isolating gravitational time dilation by considering static objects in a gravitational field, with a focus on hypothetical scenarios involving rockets near a black hole.
  • A participant questions whether gravitational time dilation affects all processes within a rocket as it approaches a black hole, to which another participant affirms that it does.
  • There are inquiries about the relevance of Oppenheimer-Snyder coordinates in understanding gravitational time dilation.
  • A response clarifies that gravitational time dilation is independent of coordinates, though its computation may vary depending on the coordinate system used.
Participants express differing views on the comparison of clock rates in various scenarios, and while some affirm the effects of time dilation, the discussion includes multiple perspectives on how to interpret and compute these effects. No consensus is reached on the best approach to demonstrate time dilation mathematically.
Participants highlight the complexities of gravitational time dilation, including the influence of orbital motion and the need for careful comparisons between static and moving objects in gravitational fields. The discussion does not resolve the mathematical intricacies involved.
bunsen1
What are the equations that shows that time slows down as you near a black hole? I'm trying to prove to a non-believer that the math is there and shows this. Thanks!
Hi bunsen1,
Have you seen the wikipedia article on gravitational time dilation? It's got a good descriptive explanation together with the equations.
http://en.wikipedia.org/wiki/Gravitational_time_dilation
You'll probably want to read the "Outside a non-rotating sphere" section.
Do note that the effect is present in any gravitational field, not just that of black holes. E.g., clocks on Earth tick slower than those in ISS.
Come back if anything's unclear.
No, they don't, because the ISS is in orbit about the Earth, which adds an extra effect due to the orbital velocity. Clocks on the ISS actually run slower than clocks on the surface of the Earth, because the slowdown due to orbital velocity outweighs the speedup due to higher altitude. (For objects in higher orbits, such as the GPS satellites, the altitude speedup outweighs the orbital velocity slowdown, so the "natural" rate of the GPS satellite clocks is faster than that of clocks on the Earth's surface. This has to be adjusted for to make the GPS system work.)
To isolate just the gravitational time dilation, you need to consider objects that are static in the gravitational field, i.e., not moving at all relative to the source of the field. Technically, this means objects on the Earth's surface aren't static either, because the Earth is rotating. A truly correct comparison that involves only gravitational time dilation would be an object at rest on the surface of a non-rotating, perfectly spherical planet, vs. an object "hovering" at a high altitude above the planet, using rocket engines or something equivalent to hold itself in place. In the case of a black hole, since there is no surface, you would compare the clocks on two rockets, one "hovering" close to the horizon vs. one "hovering" much higher up.
Welp, that's a brainfart. Thanks for the correction. I actually had written GPS satellites there, before chaning it to "something more iconic" without thinking of the huge difference in orbital radii.
"In the case of a black hole, since there is no surface, you would compare the clocks on two rockets, one "hovering" close to the horizon vs. one "hovering" much higher up."
If you are in one of the rockets nearing the black hole, does the gravitational time dilation apply to all things affected by time, including biochemical processes, as you get closer and closer to the black hole? In other words, everything slows down inside the rocket, not just relative to another object?
bunsen1 said:
If you are in one of the rockets nearing the black hole, does this time dilation apply to all things affected by time, including biochemical processes, as you get closer and closer to the black hole?
Yes.
Can't this be seen in Oppenheimer-Snyder coords?
What do you mean by Oppenheimer-Snyder coordinates?
(The general answer to your question is that gravitational time dilation is independent of coordinates; it's defined in terms of the time translation symmetry of the spacetime. But how to compute it can be more evident in some coordinates than others.)
  • · Replies 40 ·
  • · Replies 31 ·
  • · Replies 51 ·
  • · Replies 22 ·
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 67 ·
  • · Replies 29 ·
  • · Replies 51 ·
