How do fiber optic pressure sensors work?
Fiber optic pressure sensors primarily operate through designs like diaphragm sensors and interferometric methods such as Fabry-Perot and Mach-Zehnder. Diaphragm sensors work by deforming under pressure, which affects light deflection and intensity returning to a photodiode. In contrast, interferometric sensors utilize changes in light path length due to pressure variations, shifting interference patterns that are detected and translated into pressure readings. While diaphragm sensors are simpler, Fabry-Perot devices are more commonly used in industrial applications due to their compact size. Overall, the choice of sensor type depends on the specific application requirements and desired sensitivity.
hxtasy
In a nutshell? i cannot seem to find a lot of information online about these. Could someone please help?
thanks!
It depends on the type of sensor. The most popular is probably the diaphragm design. They are basically just a regular fiber with a diaphragm on the end that is normal to the fiber. Light is sent to the end of a fiber via a fiber coupler and received by a photodiode/phototransistor. As the pressure increases, the diaphragm deforms and causes more light from the fiber to deflect thereby lowering the return intensity/optical path.
Here's a white paper about some commercial ones pressure sensors:
http://www.fiso.com/modules/AxialRealisation/img_repository/files/documents/2007/Miniature%20Fiber%20Optic%20Pressure%20Sensor%20for%20Medical%20Applications%20IABP%20therapy_2005%20OFS-17.pdf
Old post, but updating in case anyone encounters this.
The previous post seems to describe a sensor based on physical dimming due to a diaphragm reducing light reflected back into the fiber. There may be a sensor like that, but the more common types are based on Fabry-Perot etalon or Mach-Zehnder interferometers, and interference patterns. There is an element in these that is sometimes called a "diaphragm", but it is related to changing the distance light travels on a leg of the interferometer. Pressure changes vary the path length, which cause the light/dark bands of the interference pattern to shift. A photo sensor detects the number of light/dark changes moving past it, and the count is then translated into a pressure.
I remember an optics lab experiment where I used a two leg fiber based Mach-Zehnder interferometer. One fiber leg of the device was exposed to the pressure to be measured, and the other shielded. The pressure changes on the exposed fiber cause internal reflection differences resulting in path differences. I think the F-P devices are more common in industry than the M-Z based, especially where small size is important.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
