T@P
- 274
an ordinary paper fire is 451 degrees Fahrenheit ( ), and the standard oven temp is 350. how do fires start in ovens? also where does the energy come for the first spark which starts the flame?
The heating coils turn red in an oven.janzizka said:how would overflow start a fire? i mean if everything in the oven is at 350 then where does the temp build? and not to sound like i didnt hear about the radiation... but isn't that more microwavish? standard (old) ovens just produce heat in some conventioinal way...
Yeah - with a red-hot heating element or an open flame.janzizka said:standard (old) ovens just produce heat in some conventioinal way...
THIS is the best I could do with a little google. A candle glows orange at 1900K - I'd think a red heating element is a little, but not much below that. A gas burner is significantly hotter.DaveC426913 said:"...somewhere between 1000 and 2000 degrees..."
I would be quite surprised if the temp of the coil in an oven reached that kind of temp. Don't forget, the coils on top of the stove and in your hair dryer glow red too. 1000-2000 degrees??
More energy because its has more mass and surface area: if the color is the same, the temperature is the same.The diffrence between the hair dryer and the oven is that it takes much more energy to get the oven up to the red hot area then the hair dryer. In short the Oven draws more current to obtain higher temps. That is all.
DaveC426913 said:"but dave for something to "glow red", the substance that glows red must achieve some temperature, and I am sure that a thick metal would have a harder gatting that glow then an incredibly thin wire as in a blow dryer. but thanks i get the idea about ovens"
Nono. All I'm saying is, I find it hard to believe that these devices would be built that could hit temperatures of 1000 - 2000 degrees. I mention the blow dryer because it comes within inches of your face.
Surely that hot a temp would be too dangerous in the hands of amateurs.
Chronos said:1200 Blood Red
1375 Low Cherry Red
1425 Medium Cherry Red
1500 Full Cherry Red
1650 Salmon
1725 Orange
1825 Lemon
T@P said:lol my oven still says 350 Fahrenheit when i turn it to 350.
Fires in ovens can start due to a variety of reasons, including malfunctioning heating elements, grease buildup, or improper use of flammable materials such as aluminum foil or parchment paper. In some cases, the oven's thermostat may also be faulty, causing it to overheat and start a fire.
Yes, leaving food in the oven for too long can potentially start a fire. This is especially true if the food is highly flammable, such as oils or fats. As these substances heat up, they can release flammable vapors that can ignite and cause a fire.
To prevent fires in your oven, it is important to regularly clean and maintain it. This includes removing any grease or food residue from the oven's interior and ensuring that the heating elements are functioning properly. It is also important to never leave the oven unattended while in use and to only use non-flammable materials inside the oven.
Using the self-cleaning feature on your oven can potentially cause a fire if there is a buildup of grease or food residue inside the oven. The high temperatures used during the self-cleaning process can cause these substances to ignite. It is important to thoroughly clean the oven before using the self-cleaning feature to reduce the risk of a fire.
If a fire starts in your oven, it is important to stay calm and act quickly. Turn off the oven and do not open the door, as this can cause the fire to spread. If the fire does not go out on its own, use a fire extinguisher or call the fire department for assistance. It is also important to have a fire escape plan in place and to never attempt to put out a large fire on your own.
