How do flourescant lights work/run out?
  • Thread starter Thread starter wasteofo2
    Lights
Fluorescent lights operate by using a gas within a glass tube that, when electrified, excites atoms, causing them to emit light as electrons transition between energy levels. The discussion highlights a common misconception about the presence of filaments in fluorescent bulbs; unlike halogen bulbs, fluorescent lights do not contain filaments. The wear-out process of fluorescent bulbs is primarily due to the degradation of the phosphor coating inside the tube and the eventual failure of the gas discharge mechanism, rather than filament burnout. This understanding clarifies how fluorescent lights function and why they eventually cease to work.
wasteofo2
I was wondering how flourescant lights work, and how they eventually wear out.
I'm not sure, but it seems that you just have halogen gas inside the glass tube, you pump some electricity into the gas, it excites the atoms and they give off light as their electrons go from higher energy levels back down to lower ones.
If I'm wrong on that, then please correct me, but it seems simple enough...
The real question I have, is how do they wear out? If all it is is atoms getting excited and giving off light, how does the light bulb eventually "die out"?
Chemistry news on Phys.org
i do believe that that is how they work, don't quote me on it, because when i know I'm right, I'm wrong
Fibonacci
One way they quit is when the filaments in the ends burn out.
Ahh; I hadn't thought that there were traditional filaments inside halogen lightbulbs that actually provided the energy to produce light, I thought it would've been more like 2 active electrodes just exciting the atoms directly...
Halogen bulbs have filaments, but fluorescent bulbs do not.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
