MHB How do I derive and solve the equation for the athlete's running speed?
Simonio
I'm having problems getting going on the following question, any help appreciated:
As part of his training an athlete usually runs 80 km at a steady speed of \(v\) km h. One day he decided to reduce his speed by 2.5 km h and his run takes him an extra 2h 40 mins.
Derive the equation \(\frac{80}{v}+ \frac{8}{3} = \frac{160}{2v-5}\) and solve it to find the value of \(v\).
Mathematics news on Phys.org
where is the problem deriving or solving
Hi Simonio!
Suppose we define $t$ to be the time it takes the athlete to run 80 km at a speed of $v$ km/h.
Can you set up the equations that correspond to the run times?
I like Serena said:
Hi Simonio!
Well I think I can say that \(t\)= \(\frac{80}{v}\) and with the slower speed \(t\) = \(\frac{80}{v-2.5}\) not sure of next step
Good! :)
With the slower speed it takes 2h40 longer, which is $2\frac 2 3$ hours.
So it should be:
$$t + 2\frac 2 3 = \frac{80}{v-2.5}$$
Can you combine the 2 equations and eliminate $t$?
I like Serena said:
Good! :)
So it should be:
OK-you've given me a good hint there!
so: \(\frac{80}{v} + \frac{8}{3} = \frac{160}{2v-5}\)
Not sure about the next bit: do I multiply throughout by \(2v-5\)?
That would make: \((2v-5) \frac{80}{v} + (2v-5) \frac{8}{3} = 160\)
Think I'm on the wrong track
Good!
You're right on track.
Continue by multiplying throughout by $v$.
I like Serena said:
Good!
Do you mean multiply by \(2v-5\)?
You already did that.
But you're still left with $v$ in a denominator.
Then I get: \(v(2v-5)\frac{80}{v}\ +v(2v-5)\frac{8}{3} = 160v\)
= \(80(2v^2-5) + (2v^2-5)\frac{8}{3}\ = 160v\)
= \(160v^2 - 400v + \frac{16v^2-40v}{3}\ = 160v\)
Not sure whether I've lost the plot here!
When you multiply $v(2v-5)$, you should get $(2v^2-5v)$ instead of $(2v^2-5)$.
That is because generally $a(b+c)=ab+ac$.
You can check this with for instance $4(2+3)$.
Furthermore, you can write:
$$v(2v-5)\frac{80}{v} = (2v-5)\frac{80}{v}v = (2v-5)80$$
That is because if you first divide by $v$ and then multiply by $v$ the effects cancel.
