How Do I Determine Force of Static Friction on a Rolling Car
The problem involves a 1450-kg car towing a 454-kg trailer, with a focus on determining the force of static friction acting on the wheels from the ground. The scenario includes factors such as air resistance and acceleration, prompting participants to explore the dynamics of forces in a system involving rolling motion.
  • Mixed
  • Participants discuss the application of Newton's laws and the relationship between net force, static friction, and air resistance. There are attempts to set up equations based on free-body diagrams and to clarify the roles of various forces involved.
There is ongoing exploration of the forces at play, with some participants providing guidance on diagramming and force direction. Questions about the clarity of the forces represented in diagrams and the correct application of equations are being raised, indicating a productive dialogue without a clear consensus yet.
Participants are navigating the complexities of force directionality and the implications of static equilibrium in their calculations. There is mention of potential confusion regarding the signs of forces in equations, which reflects the challenges of accurately representing the physical scenario.
Liam C
A 1450-kg car is towing a trailer of mass 454-kg. The force of air resistance on both vehicles is 7471N[backward]. If the acceleration of both vehicles is 0.225m/s^2[forward], what is the force of static friction on the wheels from the ground?
Fnet = ma
Ff,s = UsFN (where Ff,s is the force of static friction, Us is the coefficient of static friction and FN is the force of the normal).
I know that since the tires are rolling, the force applied must be backward and the force of friction must be forward. As a result, the final answer should be positive.
Mc = 1450-kg, Mt =454-kg, FairR = 7471N[backward], a = 0.225m/s^2[forward], Δm = Mc + Mt, Ff,s = ?
Because of Newton's third law, I know that the applied force has a reactionary force pushing the car forward. As a result, the net force of the entire system(trailer and car) is:
Fnet = Δm x a
Fnet = (1450 + 454)(0.225)
Fnet = 428.4N [forward]
Given this, I think that I should find another equation for net force and then either solve for Ff,s or Us. I have tried this several times, but I can't seem to get it right. I would really appreciate some help as I have been stuck on this problem for hours.
Fnet = ma
Fnet = Δm x a
I think the first thing you need to do is draw a diagram showing all of the forces and their directions. That should make it a lot easier to write your second equation for the net force.
Yes, I have already done that, and I have attached it.
Based on this I think the sum of the forces equation looks like this:
Fnet = Fr + Ff,s - FairR - FA
Am I on the right tracK? I am having trouble extracting an answer from this.
I should mention that that diagram is as if the two vehicles were a single object.
I am not sure what all of your forces are, and I don't see ##F_{net} = ma## in the diagram at all. You already know that the force of air resistance is backward. That looks correct in your diagram. You also have the force of static friction in the diagram and you have assigned a direction. What ##F_a## and ##F_r## represent is not clear. I think the three forces, ##F_{net}##, ##F_{airR}## and ##F_{f,s}## are the only ones you need for your ##F_{net}## equation.
Thank you for your help, I really appreciate it.
FA was supposed to be the applied force from the tire onto the ground and Fr was supposed to be the reaction force from FA. I'm going to try to write an equation with just those three forces now.
When you make a free-body diagram like that, you need to be careful to just draw in the forces acting on the object, and no forces on other objects. So in your problem, you don't need to draw the force of the wheels on the road. It would just cancel out the force of the road on the wheels. And in this case, the (forward) force of the road on the wheels is just ##F_{f,s}##, the force of static friction on the wheels. So ##F_{f,s}## and ##F_r## mean the same thing in your diagram.
Ohh that makes so much more sense! I will think of that from now on.
Fnet = Ff,s + FairR
Ff,s = Fnet - FairR
Ff,s = 7899.4
Ff,s = 7.90 x 10 ^ 3 N [forward]
Thanks again!
Liam C said:
Fnet = Ff,s + FairR
Ff,s = Fnet - FairR
Ff,s = 7899.4
Thanks again!
In your diagram ##F_{airR}## and ##F_{f,s}## point in different directions, but in your equation you give them the same sign. So your answer must be incorrect. Here is the way to do it without errors - all the force have to add to zero, so set 0 equal to their sum. Give all of the forward-point forces a positive sign in the sum, and all of the backward-pointing forces a negative sign.
For a static equilibrium, all forces must balance. Such is not the case here.
F=ma. All the forces have to add to ma.
In my equation they do not have the same sign. In the first line I am adding a positive number (Ff,s) to a negative number (FairR). When I move the FairR to the other side of the equation and subtract, it becomes a double negative, making it a positive. As a result, I add the net force to the force of the air resistance.
Right. One of his forces is ##F_{net} = ma##.
Normally students in introductory courses are taught to work in inertial frames of reference where "ma" is on one side of the equation and all of the forces ##F_{net}## are on the other. I was hoping to guide @Liam C toward the more standard way of casting the equation.
OK. I think that works.
You are right. And I think that is what he did anyway.
  • · Replies 30 ·
  • · Replies 42 ·
  • · Replies 22 ·
