How do I determine θ'' and tension in a speed-governing mechanism?
  • Thread starter Thread starter EserRose
    Mechanism
To determine θ'' and tension in a speed-governing mechanism, the initial parameters include mass (m = 0.2 kg), length (L = 10 cm), angular velocity (w = 500 rpm), and angle (θ = 40°). The angular velocity is converted to radians per second, yielding ω = 52.36 rad/s. The tension is calculated using the vertical component of forces, resulting in T = 2.56 N. The discussion highlights confusion regarding the use of polar coordinates and the distinction between net force and centripetal acceleration. Understanding the frame of reference is crucial for accurately analyzing the forces involved.
EserRose
In the speed-governing mechanism m = 0.2 kg, L = 10cm, (rods AB have negligible mass), w = 500 rpm, θ = 40°,θ' = 0 . Determine θ'' at that instant and the tension in the rod.
F=[ω][/2]r
First, I calculated ω = 500 rpm * 2π /60 = 52.36 rad/s.
From the vertical components, I determined T*cosθ = mg
So T = 2.56 N
With this, I can calculate the horizontal component of T, but then I have a different ω for the balls and I'm confused. Should I use polar coordinates? If so, how should I start?
EserRose said:
F=[ω][/2]r
What is F here? If it's a force, the dimensions don't match.
How do you mean? Remember, this is not equilibrium.
Ooos I meant m*ω^2 *r
I see that, so I should find the net force then?
Sort of.. depends whether you want to use the inertial frame + centripetal view or object frame + centrifugal view.
In the latter case it would be net force; in the former you might describe it as the excess acceleration.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
