How do I determine the linear/non-linearity of this problem?
This discussion focuses on determining the linearity of a system using the principles of superposition and homogeneity. Superposition states that the sum of inputs results in the sum of outputs, while homogeneity indicates that scaling an input scales the output by the same factor. The transformation operator T is crucial for analyzing the relationship between discrete and continuous functions, specifically y[n] = T{x[n]} and y(t) = cos(3t)x(t). To establish linearity, one must verify the conditions T(a + b) = T(a) + T(b) and T(ka) = kT(a).
  • Understanding of linear systems theory
  • Familiarity with discrete and continuous functions
  • Knowledge of transformation operators in signal processing
  • Basic principles of superposition and homogeneity
  • Study the properties of linear transformations in signal processing
  • Learn how to apply the superposition principle to various functions
  • Investigate the implications of time-invariance in systems
  • Explore examples of linear and non-linear systems in engineering contexts
Students and professionals in engineering, particularly those focused on signal processing, control systems, and mathematical modeling of dynamic systems.
Lapse
Determine whether the system is (a) linear, (b) time-invariant:
y[n] = T{x[n]} = x(t)
y(t) = cos(3t)x(t)
A system is linear if it satisfies the properties of superposition and homogeneity.
Superposition: adding the inputs of two systems results in the addition of the two outputs.
Ex) x1(t) + x2(t) = y1(t) + y2(t)
Homogeneity: multiplying the input by some scalar value is equal to the output multiplied by that same value.
Ex) ax1(t) = ay2(t)
After doing some internet searching, I also found this equation for superposition: f(a+b) = f(a) + f(b)
However, I don't know how to apply these rules to determine whether my equations are linear or not.
My attempt for determining SP:
y1[n] + y2[n] = T{x1[n] + x2[n]} = n(x1[n] + x2[n])
If my attempt at SP is correct, what is the next step? If it is wrong, what is the right way to write it, and then what is the next step?
What is the operator ##T\left\{\cdot \right\}## ? ##n## is natural ? ##y[n]## is discrete and ##y(t)## is continuous ? Can you define better this system before to start to prove the two conditions ?
Ssnow
Ssnow
Thank you for your reply Ssnow,
The second equation is a separate problem; apologies for being unclear. We can ignore that.
So for now we are just dealing with the discrete problem. Unfortunately, I am unsure what the T{} operator is for. I would guess that it is an arbitrary value representing a function of a function; i.e. x[n] is a function of T. Again guessing, I think n is some arbitrary value; it could be a, or b, or whatever else.
So this is the one you are concerned with?
I understand the first part, y[n] = T{x[n]}, but not why this would be equal to x(t).
Here T is some transformation that is applied to x[n] to produce y[n].
No, you have this backwards. y[n] is a function of x[n] via the transformation T. T is a transformation that operates on a sequence or function x[n]. It is not a value.
Finally, if you are not given a formula for T, there is no way you can tell whether it is linear or time-invariant. Are you sure that the second equation, y(t) = cos(3t)x(t), isn't part of this problem?
For a transformation T, Tis linear if T(a + b) = T(a) + T(b) and if T(ka) = kT(a), where a and b are in the domain of T, and k is a scalar constant.
Thank you for your reply Mark,
I am positive that the second equation is for a different problem because it is delineated as (2); instead of being a part of problem 1. However, maybe we should switch over to the 2nd problem if we can't discover the answer to the first one.
So, do I start by creating y1 & y2 and add them together?
y1(t) + y2(t) = cos(3t)[x1(t) + x2(t)]
What do I do next?
What do I do next?
You're still going at this backwards.
From post #1: y(t) = cos(3t)x(t)
For linearity, you need to show (1) that ##y(t_1 + t_2) = y(t_1) + y(t_2)## and (2) that ##y(kt_1) = ky(t_1)##.
So for (1), ##y(t_1 + t_2) = \cos(3(t_1 + t_2))x(t_1 + t_2)##. Does that work out to ##y(t_1) + y(t_2)##?
It would be helpful if you showed us the exact wording of the problem. If it's a problem in a textbook, upload a photo of the problem. As presented in this thread, there seems to be a lot of missing information.
15K
15K
