How do I go about this [projectile motion]
The discussion revolves around calculating the projectile motion of a rocket launched with an initial velocity of 75.0 m/s at a 53-degree angle, which experiences a net acceleration of 25 m/s² for 25 seconds before its engines fail. Participants clarify that the rocket's final velocity after the powered phase becomes the initial velocity for the projectile motion phase. The problem must be solved in two parts: first, determining horizontal and vertical distances and speeds during powered flight, and second, analyzing the free-fall trajectory after engine cutoff. The importance of separating the two phases and calculating the initial height from the first part is emphasized. Additionally, while considering the Earth's curvature could enhance accuracy, it is suggested to focus on the basic calculations for this problem.
IntellectIsStrength
A rocket is launched with an initial velocity of 75.0 m/s [53 degreess above the horizontal]. It goes for 25.0 s along its initial line of motion with an overall acceleration of 25 m/s^2. At this time the rockets fail and the rocket follows a projectile path. Find the total time, dy, and dx, in no particular order.
so would the vx and vy be:
vx=700cos53 m/s
vy=700sin53 m/s
(700 is the vf of the rocket after 25.0 s, before getting into a projectile path; so is it correct to assume that 700 is the vi for the projectile?)
And so far I've come up with dy = tan θ + ½ a (dx/ Vicosθ)^2... I really don't know what to do next... :confused:
I'm not sure exactly what work you're showing or where you got the answers you give, so let me give you some general advice here.
Notice that the conditions of the problem change partway through. That means you're pretty much going to have to solve the problem in two parts.
During the first part, the rocket starts with the initial velocities you have worked out. It also has an "overall acceleration" of 25 m/s^2. I presume that means the net acceleration, and that gravity has been taken into account, so you'll need to split the acceleration into its horizontal and vertical components and figure out from that the horizontal and vertical distances traveled as well as the final horizontal and vertical speeds.
When the rocket engines cut off, the second part of the problem begins. Now you'll use the final velocities you worked out in the first part as the initial velocities in a free fall problem. The rocket will be rising at thus and such a rate - how long until it hits the ground? Obviously, to get that you'll need to know the initial height, which will be the vertical distance you determined in the first part.
Does this help?
Oh - and for the record, I suspect you'd have to take into account the curvature of the Earth to get an accurate answer to this question, but I think I also wouldn't worry about that if I were you. I'd just use it to tease my teacher. :)
