Optimizing GPU Temperature: Tips and Tricks
  • Thread starter slee95
  • Tags
    Gpu
In summary, the computer will be at 56°c when the door is closed but will be at 54°c when the door is open. I have a fan under the card and on the side of the card. Both fans are 80mm.Is your gpu overheating?1. use the gpu less2. use a different cooling method
slee95
132
It will be at 56°c when the door is closed but will be at 54°c when the door is open. I have a fan under the card and on the side of the card. Both fans are 80mm.
Computer science news on Phys.org
1. use the gpu less
but you know this: what is your real question?
Get a sheet of acrylic to replace the side of your case. Cut a couple of holes in that and glue short lengths of acrylic tubing so that the tube directly connects room air to the input side of each fan. (You could, just as a first quick cheap experiment, try this with cardboard, duct tape and staples. Do a good job and if it shows substantial results then do the more impressive job with clear acrylic)
Some Dell computers have have plastic ducts that route room air from openings on the back of the case directly to the top of the CPU fan. You are just doing the same for your GPU fan and CPU fan.
If you wanted to really impress people you could come up with a portable room air conditioner and duct the cold dry air out of that into your GPU and CPU input ducts.
Or if you want to go steampunk you could get some sheet copper and tubing and a good sized soldering iron and make yourself some copper fins bonded onto a copper tray. You fill the copper tray with crushed ice and the fans pull air past the cold fins cooling the air before it is sucked into your case.
Watch out for condensation. Sucking water into your computer might not be a good idea, but I did once wonder for a few hours whether it would be feasible to blow a mist of fine water droplets onto the CPU heatsink where it would immediately evaporate and decrease the temperature substantially. I feel I must say I am not responsible for any damage caused by trying this, but if someone does try it and gets video showing substantial temperature drop I think you might have some youtube material there. Post to let me know.
If you haven't already done so and your gpu isn't new, buy some compressed air and blow out any accumulated dust. Disassemble the thing if you have to, but dust can be a major problem for getting rid of heat.
If the computer is a name brand prebuilt the case is likely not really designed for serious cooling or upgrades like a gpu that produces heat. If you have just added a video card where none was before I'd suggest drilling a few extra holes in the front bottom or front bottom sides of the case to allow more air in for the gpu fan to suck on. If dust is a problem even dryer anti-static sheets can be used for dust filters. Without knowing more about your exact setup it's impossible to make anymore recommendations.
this sounds like a cool idea and i will talk to my red necking buddy's about it. :) the gpu is right now at 56c.
The case is made by acer and the mother board had a built on video card but i wanted to try a digital video card and see if there is a difference.
I can post picture of the computer but i only know how to upload it to fb.
What we really need are the model and specifications. You can download Everest or CPU-Z and GPU-Z and tell us what you have plugged into the thing.
NVIDIA: 57% ATI: 36% Intel: 6% Other: 0%
Bus Interface:
PCI-E: 42% PCI-E 2.0: 21% PCI: 11% Other: 23%
DirectX Support:
10.0: 37% 9.0c: 17% 10.1: 15% Other: 31%
I have a screen shot on fb of SpeedFan 4.43. and it has all the speeds of my fans and the temps.
Did a screen shot of TechPowerup GPU-Z 0.6.3 and posted it to fb My fb account is shawn lee.
With an ATI video card, you can enable ATI overdrive, not to speed up the clock rates, but to speed up the fan with a manual setting, somewhere between 25% and 40% should be enough, but check the temp of the GPU after running a game for a while.
Please provide a link or list the model of acer computer it is and the model of graphics card.
Ok everything may not be correct because this is a refurbished Computer. http://www.geeks.com/details.asp?invtid=AM3100-U3201A-R&cm_mmc=geekmail-_-newarrivals_html-_-07jun08-_-AM3100-U3201A-R The hard drive and the ram are 2gb of ram and 200gb Hard drive mother board is all Original. The operating system is xp.
1. How do I check my GPU temperature?
To check your GPU temperature, you can use software such as MSI Afterburner, GPU-Z, or HWMonitor. These programs will display your GPU temperature in real-time.
2. Why is my GPU temperature so high?
There are several reasons why your GPU temperature may be high, including insufficient cooling, a dusty graphics card, or demanding applications. It's important to make sure your computer is properly ventilated and that your graphics card is regularly cleaned to prevent overheating.
3. How can I lower my GPU temperature?
To lower your GPU temperature, you can try adjusting your graphics settings to reduce the workload on your graphics card. You can also improve ventilation in your computer by cleaning dust and debris from fans and ensuring proper air flow.
4. Is it safe to overclock my GPU to lower its temperature?
Overclocking your GPU may lead to lower temperatures as it allows for more efficient processing. However, it also increases the workload on your graphics card and can potentially cause damage if not done properly. It's important to research and follow safe overclocking practices if you choose to do so.
5. What is a safe GPU temperature?
The safe GPU temperature can vary depending on the model and manufacturer. As a general rule, it's recommended to keep your GPU temperature below 85-90 degrees Celsius. Higher temperatures can potentially damage your graphics card and decrease its lifespan.
  • Computing and Technology
  • Mechanical Engineering
