athena810 said:
Will this work?
So definition of | |: The positive value of any real number.
Case 1: If x, y >= 0..then |x| = x, |y| = y, xy >= 0. Thus |xy| =xy = |x||y|?
OK you give an informal definition that sounds like what someone said in class explaining it to you. And maybe your memory. H of I is surprised if that is in a book. Use the book.
To be able to use definition you really need the formal one given by HofI.
This bit
is OK. The rest is all true but it doesn't seem to me a proof argument.
I suggest you do things like this by numbers so it is clear where everything comes from and fits in. I will give my version as model with which you could do the second bit.
1 Definition of |x| as per HofI. (Def 1)
Remark: use of the ≥ has reduced our cases to two not three.
2 Case 1. x ≥ 0, y ≥ 0 (condition A)
By Def 1 (1) |x| = x, |y| = y. Therefore in case 1 |x|*|y| = x * y
3 Still case 1, from condition (A), x * y ≥ 0
4 From Def 1 and 3, |x * y| = x * y
5 Two things that are equal to a third thing are equal to each other.
So the two things we found above each equal to x*y are equal to each other, i.e. |x|*|y| = |x * y|
6 Case 2, |x| ≥ 0, |y| < 0 ...
I don't say this is perfect (it is not my field) but do you see this more like a logical proof, not a handwaving?
It lays bare assumptions, e.g. 3 is I guess an assumption carried over from basic arithmetic and algebra, and line 1 of 5 is an assumed property of " = " , I think you will hear talk of "equivalence relations".
