How do I set up the equations for this?
  • Thread starter Thread starter Ryuk1990
    Set
To find the reactions at point A, the equations for forces in both x and y directions must sum to zero, as well as the torques. The force equation in the y direction is Ay + 300 - 100 - 200 = 0, leading to Ay = 0. For the moment equation, the correct formulation includes the moment provided by the support at A, resulting in A - 100(12) + 300(15) - 200(22) = 0. This calculation yields A = 1100, confirming the need to account for all forces and moments. Understanding these principles is crucial for solving equilibrium problems effectively.
Ryuk1990
I am to find the reactions at A. How would I set up the equations for Ay and Ax in this problem? It seems pretty confusing. Also, will there be a momentum in this problem?
This system is supposed to be in equilibrium, right? In that case, forces in both x and y directions must sum to 0 and torques must sum to 0. Write out those conditions in 3 equations, plug in the numbers, and you'll get the answer.
Well for forces in the X direction, it's just A (in the X direction) is 0, right?
For y direction, this is the equation I wrote down.
Solving for the unknown, I got Ay = 0.
As for the momentum of A, here's what I wrote down. It doesn't exactly make sense to me.
-100(12) + 300(15) - 200(22) = 0
but...that comes out to -1100 = 0 which makes no sense? What's going on? Is the momentum of A just -1100?
You are using the wrong terminology;it's the moments (or torques) of all forces about A that must equal 0.
Since the support at A is fixed, it is capable of providing both forces and moment (or torque, or couple; these terms are sometimes used synonymously). So in your equation, you are missing the moment provided by the support at A.
PhanthomJay said:
You are using the wrong terminology;it's the moments (or torques) of all forces about A that must equal 0.Since the support at A is fixed, it is capable of providing both forces and moment (or torque, or couple; these terms are sometimes used synonymously). So in your equation, you are missing the moment provided by the support at A.
So the moment at A would be written like this?
A = 1100
Also, was I right about the forces in the x and y directions?
