How Do Kinematics and Impulse Principles Apply in a Two-Particle Pulley System?
In the discussion on the application of kinematics and impulse principles in a two-particle pulley system, the problem involves two masses, 8 kg and 5 kg, connected by a string over a pulley. The tension in the string was calculated as 800/13 N, with an acceleration of 30/13 m/s² for both particles. The participants sought clarification on the term "jerked into motion," concluding that it refers to the initial movement of the system when the 8 kg mass hits the ground, causing the 5 kg mass to decelerate. To find the impulse on the string, they determined that the initial velocity at the point of jerk should be used, with the final velocity being zero. The discussion highlights the need for a clear understanding of impulse and kinematics in solving the problem effectively.
songoku
Two particles of masses 8 kg and 5 kg are connected to the two ends of a light inextensible string which passes over a fixed smooth pulley. Initially each of the two particles are held at a position which is 5 m above a horizontal ground. The objects are then released from rest. Assuming that the particles never reach the pulley, and also that the particles do not rebound when thhey strike the ground.
(i) find the tension in the string and the acceleration of each particle
(ii) find the distance above the ground of the point H, the highest point reached by the 5 kg mass
(iii) find the speed with which the system is jerked into motion and the impulse experienced by the string during the jerk.
F = ma
Kinematics
Impulse = change in momentum
p = mv
I'm able to do part (i) and (ii). For part (i), I got T = 800/13 N and a = 30/13 ms-2
I don't understand how to do the part (iii). What is the meaning of "which the system is jerked into motion"? I think maybe I have to find the speed when it moves for the first time, but no information about time given...
Thanks
Find the velocities of masses when 8 kg mass hits the ground.
At that instant T becomes zero. 5 kg mass stops accelerating. That may be the point of jerk. After that 5 kg mass retards with g. You can find distance traveled by it before coming to rest.
Hi rl.bhat
Oh, that's the point of jerk. Then to find the impulse on the string, take the initlal velocity as the velocity of point of jerk and final velocity = 0?
Thanks
Can u solve the question ii/ and iii/ a bit clearly...THx
