Sherwood Botsford said:
Very common, and not quite.
The not quite happens because the reaction to changing circumstances is not instant. There will be a lag of some time while the temperature warms up enough to make the required change in radiation.
But temperature is instantaneous, as it is practically the same thing as emitted energy considering that the fourth power of degrees Kelvin is what defines the amount of energy leaving matter at a certain temperature. Isn´t it a bit of a contradiction to talk about lag when explaining changes in temperature?`
When temperature rises it always is caused by an increase in energy going into a system. The change in input is instantaneous and the matter that receives that energy changes instantaneously. Warming is the result of an increased amount of heat going into a system continously.
The lag you are talking about, isn't that the time it takes for the increased amount of energy to get evenly distributed throughout the system eventually reaching a steady state?
Excited matter at a given temperature is totally dependant on constant input of energy, in cases like this when matter gets heated from the outside. Any change in the amount of input will immediately give an equal change in excitation.
If input was shut off entirely to earth, how long time would pass before the planet reach equillibrium in cold space?
On Earth radiation is complicated.
More than other planets? In what way?
Right now we are experimenting with this effect on the Earth. We've added a bunch of stuff to the air that slows down the radiation from the surface. The current estimate of the differential between in and out is about 1W/m2, or about 0.1% So the temperature of the planet is slowly rising. Depending on what we do about the stuff, we may end up with palm trees in arctic regions within a thousand years. (In my home province of Alberta, ecozones are moving north at an average of 10 km per year. 2080 for us is 5-9 C warmer than at present. The joys of living at higher latitudes -- stronger climate effects.)
How can radiation be slowed down? Doesn´t radiation, if we talk about speed, have the same speed as the photon? Doesn´t all photons, both IR and SW, have the speed of light?
Did you mean that it takes a longer route, traveling through more molecular absorption in greater numbers and decreasing in energy with every emission that results from added absorbing molecules? It takes longer time for a single photon to travel from the surface to space, if more molecules absorb the photon before it reaches the boundary. But slowing it down, is that really what happens?
Does anyone know how long time we are talking about? How much longer does it take for a photon to leave the atmosphere and enter space, when there are a certain amount or a certain increase in absorbing molecules when the photon travels at light speed? Is it minutes, seconds, hours or what?
Since photons reach Earth in ten minutes when they travel from the sun, it seems like the short distance in the atmosphere would be done very fast even with an absorbing gas in the way.
Water can hold lots of absorbed heat radiation over time, but even water emits that energy and drops in temperature quickly if the input or surrounding temperature drops. Other absorbing gases doesn´t hold the energy for very long at all as radiated photons. As far as i know, they emit it practically instantaneously, and if they don´t, they will instead collide with the other gas molecules and release it equally fast in the process of transformation to kinetic energy, heat.
Isn´t it so, that most of the transfer of energy in the atmosphere is by kinetic transfer?
I know that I have read that close to the surface there is no radiative heat transfer and it is entirely a process where conduction moves heat through convection, transferring it in moving matter that expands as it warms up. Of course there must be radiation from the surface somewhere sometimes, but the main mechanism of heat transfer is done by conduction and convection close to the surface, is that right?
Convection is a slower form of moving heat than radiative transfer of individual photons, but it compensates by being more effective. With added mechanisms like waters phase change to gas form when it´s energy content drives individual molecules to carry the heat away from the surface, I have been told that it is preferred method of heat transfer when possible. Mass that carries the energy as kinetic energy or as absorbed photons. Isn´t that right?
It´s weird to use terms as "preferred" when talking about heat transfer. It´s more like, when conduction and convection is possible, it will happen before radiative transfer, as I have understood.
It seems a bit misleading when the slowest form of transfer as energy contained in matter carrying the heat away from the surface, is the dominant form of heat transfer from the surface, and the argument is that radiative transfer of photons that travels at light speed is slowed down in a process that also attenuates it. And also, the slowest way of energy moving to space, seems to be the most effective method of cooling the surface. Slowing down radiation is a strange argument when considering the speed of photons and the very effective but slow transfer by convection.
There must be a better way to explain it.
And you also write that there is an inbalance in energy of 1W/m^2. The radiated energy that is lowered by 1W/m^2 in output, is equal to a lowered temperature by the same amount of energy. This is confusing.
Temperature is equal to the energy emitted and the fourth power gives us W/m`^2. When you say that a radiative imbalance that has decreased by 1W/m^2, which is the same as saying that the emitted radiative temperature has dropped with the same amount of energy, how do you mean that it is connected to a rising temperature?
Does the temperature drop first at higher altitude and then the surface heats up? Or does the temperature rise at the surface first and that causes a drop in temperature at higher altitude?
In both cases it seems like they cancel out. As I know heat transfer, a drop in temperature is not something associated with increasing temperature and energycontent in a system. Actually, it never happens that temperature drops in the same process that temperature increase in different locations in a system. At least in the heat transfer literature I have read.
It would be nice to get some clarification of these processes and how earth´s temperature is governed by the gasses in the atmosphere.
