How Do Potential Dividers Work with Constant V(input)?
  • Thread starter Thread starter evry190
    Potential
The discussion revolves around understanding the behavior of a potential divider circuit involving a potentiometer and a constant voltage source, specifically a battery. Participants are exploring the relationship between input voltage (V(input)) and output voltage (V(output)) in this context.
  • Participants are questioning whether V(input) remains constant when using a battery and how changes in resistance affect V(output). There is confusion about the implications of using a constant voltage source and the ability to vary V(input).
The discussion is ongoing, with participants providing insights into the nature of battery voltage and its practical variations. Some have suggested that the original poster clarify their experimental setup and whether they are meant to vary V(input) or resistance.
There is mention of potential constraints such as the original poster's lab manual instructions and the need for clarity on the experimental requirements. Participants are encouraged to provide diagrams to aid understanding.
evry190
I have a simple series circuit with one potentiometer, and I'm supposed to find the V(output) for various V(input). However, I think that V(input) is constant isn't it, because it's the voltage of the battery...right? I know I can change the resistance and make V (output) change, but V(input) should be unaffected right? I'm stuck : (
For a potential divider with two resistances R1 and R2
the voltage across R1 is
V1=R1/(R1+R2)V
i know but, isn't v(input) constant?
Yes, but if you change V(input), V(output) changes appropriately for given resistances.
how do i change V(input) if it comes from a constant voltage source such as a battery
sorry i don't mean to bother you, i really appreciate your help
but I'm still a bit confused
You'd need to change the battery itself.
You could replace the battery with a variable voltage source such as a programmable bench-top power supply. :smile:
No, seriously though. Circuits similar to what you describe do have applications. Examples of such circuits are; or are likely used within:
(a) Battery testers. These things can be used to test whether or not a battery is fully charged. If you have one you can decide which batteries to keep and which to recycle.
(b) Battery chargers. This one is pretty obvious. If the voltage of the battery's terminals reaches a certain point, the charging algorithm changes or stops altogether.
(c) Low-voltage drop-out (LDO) regulators. These are in nearly all portable electronic devices these days. Basically the regulator shuts off power to other circuits if the battery voltage (or even if output voltage) gets too low, to prevent unwanted behavior (such as memory getting corrupt or something).
I suppose the general idea here is that battery voltage does change a little depending on how fully charged the battery is. And in practical applications, it's useful to account for this. So often times, it's generally not a good idea to assume that batteries always have constant terminal voltages.
Is that all you were given (is this the whole question)?
If they gave a diagram of your circuit, could you please upload it?
If not, to help us understand your thought process, could you please draw and upload your own
diagram (labelling Vin, Vout, gnd, resistances on either side of the potentiometer wiper, etc..)?
Like this one
http://www.iop.org/activity/education/Projects/Teaching%20Advanced%20Physics/Electricity/Images%20100/img_mid_4088.gif
where v(input) comes from a battery.
The thing is, in my experiment, I'm not changing the voltage from the power supply.
I'm only turning the knob on the potentiometer.
thank you for helping me, i appreciate it very much
If you're turning the knob on the potentiometer, you're changing the resistance. You can never change two things at the same time during your experiment (ie. you wouldn't turn the knob on the potentiometer AND vary the input voltage, you'd do one or the other). If your lab manual says to do so you may want to check with your prof, because it could be a mistake.
Are you sure you're supposed to be finding Vout vs Vin, not Vout vs R?
According to what you have described and what your circuit shows, you are right, you are only changing the resistances of your voltage divider (potentiometer), not the supply voltage (Vin). The only way you can find Vout for various Vin, is to be able to vary the power supplied. And if you are varying the power supplied, I would do that for one setting on the pot at a time.
  • · Replies 22 ·
