How do simplicial maps induce maps between barycentric subdivisions?
  • Thread starter Thread starter malicx
    Induction
malicx
This is from Armstrong's Basic Toplogy, p131. It's about simplicial maps, and barycentric subdivisions where m is the m-th barycentric subdivision (defined inductively by Km
= (Km-1)1
Show that a simplicial map s: |K| --> |L| induces a simplicial map from |Km| to |Lm| for any m.
I've got a theorem from page 126 that says |K1| = |K|. I just want to say that since the complexes and their subdivisions are equal, then we should have |Km| = |K| by induction, and the same for |L|, so we have the given map. This seems far too simple, but I am not exactly sure where else to start.
bump :)
i'm still stuck at this point! does anyone have any advice? Perhaps I should just say that since s is simplicial, it takes simplexes linearly to L from K, and since KM contains K, and LM contains L, we have the obvious map.
The problem with your line of though is that yes we have an induced map,
f : |K^m| \to |L^m|
but you still need to verify that it is a simplicial map. In other words you need to confirm that it takes simplexes of K^m linearly onto simplexes of L^m (or if it doesn't then find a different way to induce a map that does).
Of course by the inductive definition of K^m it suffices to show that you get an induced simplicial map
f : |K^1| \to |L^1|
It is not obvious that this is simplicial since K^1 has simplexes not in K.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
