How do speed laser guns differentiate between two cars?
Laser speed guns differentiate between vehicles by using a narrow beam that allows operators to target specific cars accurately. While they are generally effective, issues can arise if the device is not held steady on the target, leading to erroneous speed readings due to "slippage." This phenomenon occurs when the laser beam slides down a vehicle's surface, potentially misrepresenting its speed. In contrast, radar guns may struggle more with distinguishing between closely spaced vehicles. Despite their advantages, laser guns are not entirely fault-free and can still produce inaccurate results under certain conditions.
RadPhi
If two cars are traveling either in parallel or in close succession to one another how can a laser determine which car it is gauging the speed of?
Science news on Phys.org
Laser beams are very narrow. When properly used, the operator can tell the cars apart.
even more simply, because of their narrow beam, they just aim at the vehicle they want to measure the speed of
As has been said, laser guns do not have the problem you seem to think but I believe radar guns do.
It's not clear that laser guns are fault free..
Perhaps this is relevant..
http://www.dailymail.co.uk/news/article-365563/The-great-speed-gun-scandal.html
Imported from America, the LTI 20.20. is used in nearly 3,500 mobile speed units hidden in police vans or cars and mounted on motorbikes.
In other tests, we found the equipment was measuring the speed of overtaking cars instead of the one being targeted.
Dr Clark says that the gun is defective because its wide beam can easily pick up the wrong vehicle. Furthermore, if the device is not held firmly on the target - and this is a difficult task - it can produce an erroneous speed result by "slippage".
I believe the problem of "slippage" is also known as "sliding" and it occurs when the beam slides down the sloping hood/bonnet of the car making it appear to be moving faster than it is. I believe officers are trained to focus the beam on a vertically flat surface like a number plate for this reason.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
