How do we integrate with respect to (dx)^2 (not dx)?
  • Level: Graduate
  • Thread starter AakashPandita
    Dx Integrate
20 replies · 8K views · last reply
AakashPandita
[tex]∫x(dx)^2=?[/tex]
and what is the difference between dx^2 and (dx)^2?
Where's this from? I've seen ##dx^2## but not ##(dx)^2##. The only way I can parse the latter is with wedge products
The integral is zero.
i.e. it has no contribution to the overall sum.
But let's be careful: where have you seen this come up?
Isn't that just short-hand notation for a double integral, i.e.,
[tex]\iint x dx dx[/tex]
I don't think you are allowed to have the same variable for multiple integrals. A double integral is integrating with respect to the area element.
Ok, but the reason I suggested this is because I recall in one of my books on integral equations, the author, when converting from IVP to Volterra Equations, use the syntax such as:
[tex]\int_0^x \int_0^x f(t) dt dt=\int_0^x (x-t) f(t)dt[/tex]
however, to be fair, he never used the syntax [itex](dt)^2[/itex] so if I am in error, my apologies.
I was trying to find the moment of inertia of a disk rotating at the axis through its center and perpendicular to it.
i got an integral for some function with (dx)^2 in it.
I strongly suspect that you have misread
[tex]\int_0^x\int_0^x f(t)d\tau dt[/tex]
Neither "[itex]dtdt[/itex]" nor "[itex](dx)^2[/itex]" has any meaning.
With all due respect Hall, I have not. It's from "A First Course in Integral Equations" by Abdul-Majid Wazwaz. It's on p. 20 and includes also, the expression:
[tex]\int_0^x \int_0^x \int_0^x f(t)dt dt dt=1/2 \int_0^x (x-t)^2 f(t)dt[/tex]
Dear lord, that's awful. I'd read the lhs as
[tex]\int_0^x \int_0^x \int_0^x f(t)dt dt dt<br /> = \int_0^x \int_0^x \left( \int_0^x f(t)dt \right) dt_1 \; dt_2 <br /> = \int_0^x \int_0^x H(x) dt_1 \; dt_2 <br /> = x^2 H(x)<br /> = x^2 \int_0^x f(t) dt[/tex]
while, what was probably meant is
[tex] \int_0^x \int_0^{t_2} \int_0^{t_1} f(t) dt \; dt_1 \; dt_2 = \frac{1}{2} \int_0^x (x-t)^2 f(t) dt.[/tex]
That's the Cauchy formula for repeated integration. And you are not allowed to write it as dtdtdt. You must keep the variables separate.
##\int_{a}^x \int_a^{t_1}\ldots \int_a^{t_{n-1}}f(t_n) \, dt_n \, dt_{n-1} \ldots dt_1 = \frac{1}{(n-1)!} \int_a^x (x-t)^{n-1} f(t) \, dt.##
##\int_{a}^x \int_a^{t_1}\ldots \int_a^{t_{n-1}}f(t_n) \, dt_n \, dt_{n-1} \ldots dt_1 = \frac{1}{(n-1)!} \int_a^x (x-t)f(t) \, dt.##
Ok. Thanks! That makes sense to me now. Sorry for causing trouble.
Please show how you derived that.
[tex]I=\int_0^R dmr^2 dm=σπ[(r+dr)^2-r^2][/tex]
and then I put [tex]dm[/tex] in first.
[tex]I=\int_0^R dmr^2 ;dm=σπ[(r+dr)^2-r^2][/tex]
What does ##(r+dr)^2## mean?
Edit: I think it should read ##dm = 2\sigma \pi r \, dr##, which is compatible with what you wrote if we take ##(dr)^2 = 0##.
Was there a textbook or a teacher who said you could square differentials? What made you think ##(r+dr)^2## is well defined?
i tried to find the area of a ring by subtracting the area of smaller circle from larger circle.
The difference in the radii is dr.
area of ring [tex]=π[(r+dr)^2 - r^2][/tex]
Why do you have "dm" in twice?
This is using the concentric shells approach ... so the volume of the cylindrical shell between ##r## and ##r+dr## is the difference in the volumes of the cylinders:
##\pi h (r+dr)^2 - \pi h r^2## where h is the height of the cylinder.
If you multiply that out, you get ##\pi h (2rdr + dr^2)## ... but ##dr^2 = 0## ... remember that "dr" comes from a limit?
You can think of it like this:
If ##dr## is infinitesimally small, then any large power of it must be even smaller than that.
But "infinitesimal" is the smallest you can get without actually being zero.
Therefore...
[edit]pwnsnafu beat me to it :)The volume of the shell between r and r+dr is much better derived by taking the surface area of the cylinder radius r (excluding the end-caps) and multiplying it by dr. You can work out why this works by sketching it out.
