How Do You Calculate Applied Force with Mass and Friction Coefficients?
The discussion revolves around calculating the applied force in the context of forces and friction, specifically using mass, maximum static friction, and the coefficient of static friction (µ). The original poster is attempting to fill in a chart based on experimental data.
  • Participants are discussing the methodology for determining the applied force and the origin of values in a data chart. Questions are raised about the calculations for the coefficient of static friction and the relationship between different columns of data.
The discussion is ongoing, with participants seeking clarification on the experimental setup and calculations. Some guidance has been offered regarding the interpretation of data columns, but there is no explicit consensus on the correct approach or values.
There is mention of performing experiments to gather data, and participants are questioning the accuracy and origin of certain values in the data chart. The original poster has not provided a specific question from their homework, which may limit the direction of the discussion.
summerchambers
I am having trouble finding the applied force when i have the mass , maximum value of static friction and coefficient of static friction µ.
Could you quote the exact question from your homework or prac work? So we can understand what this is about.
There is none . I have to fill in the chart by preforming experiments
can you please help
Where did the values in column E come from?
Did you measure the values in column D?
What is the equation this experiment is going to confirm?
it has to deal with Forces and Friction
i did the mass with 6 trials , each different amount in the masses
and to get the coefficient i used Fmax to find the coefficient. so i put Fmax / Fpress which for trial 1 was 1/ 9.8 because Fpress=mg=9.8m
I don't think you have correctly explained where those figures in column E came from. You seem to have invented them. I believe each should be a calculated value for μ based on the data to its left.
The numbers in column C will be, I think, those in column B but each multiplied by 9.8
