quincy harman
- 41
- 0
How do you calculate change in time at the speed of light?
The discussion revolves around the calculation of time changes at relativistic speeds, particularly at or near the speed of light. Participants explore concepts such as time dilation, reference frames, and the perception of time by observers in different frames of reference.
Participants express differing views on the interpretation of time dilation and its implications, with no clear consensus reached on the nuances of the concepts discussed. The conversation remains unresolved regarding the precise implications of time dilation and how it relates to observation.
Limitations include the need for clarity in terminology and the dependence on specific frames of reference for accurate calculations and observations. The discussion also highlights the complexity of relativistic effects and their interpretations.
You don't because (1) you can't GO at the speed of light and (2) there IS no change in your time as you speed up, so even if you are talking about an achievable .999999c, your clock still ticks at one second per second.quincy harman said:How do you calculate change in time at the speed of light?
At .9c, the time dilation factor is about 2.3. So you would each see the other as moving at a little less than half speed.quincy harman said:and if you're traveling at .9 c for one hour how much time would have passed for people observing you?
so if you're moving .99c away from the galaxy it would appear to be rotating slower?phinds said:And keep in mind that "traveling at .9 c" is a meaningless statement by itself. You have to specify what you are using as a frame of reference. The assumption is that you mean .99c relative to an observer, but it's best to specify that.
Yes. When you are moving relative to something that something always looks slower. At normal (human "normal" that is) the difference is negligible but at relativistic speeds you can use the Lorentz Transform to see the relationshipquincy harman said:so if you're moving .99c away from the galaxy it would appear to be rotating slower?
Athul Prem said:The time affecting your body at speed of light is in relative to the observer for you your time is just normal for you but relatively slower for an observer.
Well, of course it is, but I'm trying to help him see that sloppy terminology lead to (or stems from) sloppy thinking.DaveC426913 said:"...your body near the speed of light..." and it's sensical.
