How Do You Calculate Momentum for a Falling Dancer and a Space Probe?
  • Thread starter Thread starter virtuoso_735
    Momentum
To calculate the momentum of a falling dancer who leaps 0.33 m high, the correct approach involves determining the final velocity using the equation v_f^2 = v_0^2 + 2aΔx, where a is 9.8 m/s². For the space probe problem, momentum conservation principles apply, requiring the initial momentum of the probe to equal the combined momentum of the expelled gas and the remaining probe mass, factoring in the vector nature of momentum. The discussion also touches on calculating force using F = m(change in velocity)/change in time. Understanding these fundamental equations is crucial for solving momentum-related problems in physics. The thread emphasizes the importance of applying the correct formulas and concepts to achieve accurate results.
virtuoso_735
Hi everyone. I have some simple momentum problems I am having trouble solving. Please help me.
A 54.0 kg dancer leaps 0.33 m high. With what momentum does the dancer reach the ground?
Well, I tried the momentum formula: p=mv. I plugged in 54.0 kg for the mass, and the velocity I put in 9.8 but of course this is wrong. I don't know how to get the velocity for a falling object (very embarassing!). Anyways, does anyone know how to get the velocity of a falling object if they jump .33 m high like in the problem so I can get the momentum? Thanks.
Here is another problem I am having trouble with:
A space probe with a mass of 7.630 103 kg is traveling through space at 110 m/s. Mission control decides that a course correction of 30.0° is needed and instructs the probe to fire rockets perpendicular to its present direction of motion. If the gas expelled by the rockets has a speed of 3.200 km/s, what mass of gas should be released?
Well, I'm not even sure which equation to use and how to do it. I tried a few equations including
mv=mv+MV and then mv=MV, trying to solve for M, but it is wrong everytime. Does the 30 degrees have anything to do with it? Can anyone help? Thanks.
You have to remember that 9.8 m/s2 is the acceleration that objects experience due to gravity near the earth.
With that in mind you can use the equation:
<br /> v_f^2 = v_0^2 + 2 a \Delta x<br />
to determine the final velocity.
For the second one, the only equation you should keep in mind is that the momentum of a system is constant unless it's acted upon by an outside force.
In this case you should equate the momentum of the space probe before the rockets are fired to the momentum of the gas plus the momentum of the remaining mass of the spaceship.
You have to be careful and keep in mind the vector nature of the momentum.
Thanks for the help. The equation helped a lot.
Here's another problem I'm having trouble with
The velocity of a 640 kg auto is changed from 10.0 m/s to 44.0 m/s in 69.6 s by an external, constant force. What is the magnitude of the force?
Do I use the equation F(change in time)=m(change in velocity)?
Nevermind...I got it. :)
Just keep in mind that in general terms the following is true: F=\frac {d\vec{p}}{dt}.
