How Do You Calculate Norton Equivalent Circuits in Electrical Engineering?
ihavaquestion
Find norton equivalent circuit
Rn=Rth
Ok i got my R(n)=34 ohms because after you turn off independent sources the resistors are in series, then I short circuited a to be and I'm trying to use mesh analysis to solve for I(n)
the problem arises with the 2 amp current source does that make I2 and I3 2 amps? help!?
  • Circuit schematic with current sources 4A and 2A, resistors 4 ohm, 20 ohm and 10 ohm in parallel branches, terminals labeled a and b, titled Find the Norton equivalent circuit.
Rn=Rth
You can write the mesh equations for the circuit and calculate the current in ab.
Or you can use superposition: cancel one of the current sources and calculate the current, then activate that source and cancel the other. The total sum of the two partial currents. current is the
You didn't label the diagram with mesh currents, so I'll guess that you have three meshes numbered from left to right in the circuit. For clockwise mesh currents i1, i2, i3, the 2A independent source will make i3 - i2 = 2A.
Note that you could also solve the problem pretty easily using superposition: you get a couple of straightforward current dividers to deal with.
