How Do You Calculate the Area Under a Complex Function?
7 replies · 3K views
fatou123
i am struggling with this question for quite few days now and i am nowhere near to an appropriate solution.
The previous ( related) question were regarding the the function
g(x)= 5+9x-2x^2 /(x^2 -6x+23)^3/2.
i have found the derivatives, the stationary point and also to classify them as local maximum and minimum which aare at x=-1/2 and x=5 .
this is the final question which i am struggling with
find the area bounded by the graph
y= (100(2x+1)(5 - x))/(x^2 -6x+23)^(5/2)
and below the x-axis. give your answer to four significant question.
I am only struggling to find the integral so i can calculate the area by myself.
so far i have found the integral of the numerator to be
100(2x+1)(5-x)
100(5+9x-2x^2)
500x+450x^2-(200/2)x^3
for the denominator i have found 2/7(x^2 -6x+23)^7/2 but i am pretty sure this is wrong.
thank you for the help.
hi fatou123! :smile:
(try using the X2 icon just above the Reply box :wink:)
fatou123 said:
… so far i have found the integral of the numerator to be
100(2x+1)(5-x)
100(5+9x-2x^2)
i assume you mean (200/3)? :wink:
sure is! :smile:
i] you cannot integrate a fraction by integrating the top and bottom separately
(it doesn't even begin to work …forget about it)​
ii] you'll need to simplify the bottom first …
either complete the square or susbtitute u = x - 3 :smile:
thank you .
after completing the square for the bottom i end up with this.
y= 100(2x+1)(5-x)
((x-3)^2 -3^2) +23)^5/2)
do i have to do the integral by part ?
thank you again tiny tim i think i am starting to crack it with a little help well a big one to be honest !
so i gather that the trig substitution might be of the form
sqrt a^2 +b^2 x^2 x=a/b tan(theta)
so far i found the denominator to be to be sqrt((x-3)^2-14)^5) and i think by using the indice rule you get to sqrt((x-3)-14)^3 for the denominator. where u=(x-3) and du=3dx
100(2x+1)(5-x)
100(5+9x-2x^2)
Do you mean g(x) = 5 + 9x - [2x^2/(x^2 - 6x + 23)^(3/2)]
which is actually what your formula says when parsed using standard rules, or do you mean g(x) = (5 + 9x - 2x^2)/(x^2 - 6x + 23)^(3/2)? If you mean the latter, you need to use brackets.
RGV
soz i meant g(x) = (5 + 9x - 2x^2)/((x^2 - 6x + 23)^(3/2)).
i still haven't learn how to do integral by substitution with trigonometry yet.
hifatou123! :smile:
without trig substitution, you'll need to write it out as
A/√(x2 - 6x + 23) + B(x-3)/√(x2 - 6x + 23) + C/(√(x2 - 6x + 23))3
and then integrate each part separately :wink:
