How Do You Calculate the Center of Mass for Multiple Objects?
To calculate the center of mass for three connected objects with masses of 5 g, 1 g, and 7 g located at specific coordinates, the formulas for the x and y coordinates of the center of mass must be applied. The x-coordinate is determined by the weighted average of the x-positions, resulting in 4.54, while the y-coordinate is calculated similarly, yielding 4.6. The total mass of the system is 13 g, which is used as the denominator in both calculations. The process involves breaking down the calculations into x and y components to find the overall center of gravity. This method is applicable to multiple objects connected by massless rods.
Shadow_C316
Three balls with masses of 5 g, 1 g, and 7 g,
respectively, are connected by massless rods.
The balls are located (in meter intervals) as
in the figure.
Imagine the first quadrant of a graph.
The 5 gram is at point (3,8)
The 7 gram is at point (5,2)
The 1 gram is at point (9,6)
What do do to find the center of gravity? I've looked online and I only see formulas for 2 objects instead of 3 so I'm stuck. Forgot to say they are all connected by massless rods.
the sum of the equations...
Sum of what equations?
the sum of the center mass equation... and you got to break it down into y and x... there is an similar example online, i'll look it up for you
Thanks so much! Would the answer be:
In the X direction
((5x3) + (7x5) + (1x9))/13=4.54
In the Y direction
((5x8) + (7x2) + (1x6))/13=4.6
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
