How Do You Calculate the Time and Speed When a Ball Hits the Ground?
  • Thread starter Thread starter calculusisfun
    Ball Hard
The problem involves a ball thrown upward from a height of 64 feet with an initial velocity of 128 feet per second, and the goal is to determine the time and speed at which the ball hits the ground.
  • Participants discuss the integration of velocity to find the position function and the implications of gravitational acceleration on the calculations. There are questions about the accuracy of the acceleration value and its sign, as well as confusion regarding unit systems (imperial vs metric).
Some participants have provided guidance on integrating velocity and determining constants, while others are exploring different interpretations of gravitational acceleration. There is an ongoing exchange of calculations and confirmations, but no explicit consensus has been reached.
There is mention of differing values for gravitational acceleration and the relevance of unit systems in the calculations, which may affect the approach taken by participants.
calculusisfun
A ball is thrown upward... hard question??
A ball is thrown up from 64 feet above the ground with an initial velocity equal to 128 feet per second. Find when and with what speed the ball hits the ground.
v = 128
anti derivative of velocity yields ---> 128x + c
since the initial height is 64, plug in (0, 64)
128(0) + c = 64
c = 64
position function ---> 128x + 64
solve for x, 128x + 64 = 0
x = -1/2
I got here and realize my answer doesn't make any sense. Any help would be much appreciated,
Thanks!
Your initial velocity = 128 ft/s.
Acceleration a = 33 ft/s2 (you can put the more accurate number).
Integrating w.r.t t yields v=33t+c
when t=0, v=128. Find 'c'.
Now integrate that again to get 'x'. The ball hits the ground when x=0, so find 't'.
How do you know the acceleration is equal to 33?
the a is more accurately 32.185 ft/s^2, but that is the gravitational acceleration on earth.
Oh... I thought it was 9.8m/s2? No? Sorry for bugging you guys haha
Oh, haha. You put it in meters. I see. :p
that is the metric system, you are using english units. So they are both correct.
if you are in an engineering course you might want to keep the english system as a course requirement.
Okay, also, is it supposed to be negative because it is pushing down or no? :\
correct
Thank you very much DarthBane, I'm going to work it out real quick (like one min) and if you could confirm that'd be awesome. :)
Ok, so I had the gravitational acceleration equal -32.174 ft/sec^2 because that's what wikipedia said haha, and here's what I did:
v = -32.174t + c
128 = -32.174(0) + c
c = 128
v = -32.174t + 128
integral of velocity ---> -32.174t^2/2 + 128t + c
-32.174^2/2 + 128t + 64
solve for this equal to zero and you get:
t = 8.42874
plug that into the first equation and you get
-143.186
So, the ball hits the ground at 8.42874 seconds with a velocity of -143.186 ft/sec. Loook right? :)
yep, you are done.
Cool, thanks a bunch
  • · Replies 18 ·
  • · Replies 17 ·
  • · Replies 19 ·
10K
  • · Replies 36 ·
  • · Replies 38 ·
