How Do You Calculate the Volume of a Rotating Body Around Different Axes?
  • Thread starter Thread starter BadatPhysicsguy
    Axis Rotation
The discussion revolves around calculating the volume of a solid of revolution formed by the area enclosed by the curve y=1/x and the line y=2.5-x, specifically when rotated about the x-axis and y-axis.
  • The original poster attempts to find the points of intersection to set up the integrals for volume calculation. They express uncertainty about how to express the volume when rotating around the y-axis and whether the area under the curves is correctly accounted for.
  • Some participants suggest a method of calculating the total volume under one curve and then subtracting the volume between the two curves, but there is confusion about the correct setup for the integrals.
  • One participant points out a potential error in the integration variable for the x-axis rotation, indicating that y should be a function of x.
The discussion is ongoing, with participants exploring different interpretations of the problem setup and the correct application of integration for volume calculation. Some guidance has been offered regarding the integration variable, but no consensus has been reached on the overall approach.
Participants are navigating the complexities of setting up integrals for volume calculation, including the need to clarify the relationships between the curves and the axes of rotation. There is also mention of potential errors in previous threads regarding the form of the integrals.
BadatPhysicsguy
The curve y=1/x and the line y=2.5-x enclose an area together. Determine the exact volume of the rotating body that is formed when this field rotates about
a) The x-axis and b) The y-axis
The formula for rotation around the x-axis is pi*integrate from b to a y^2 dy..
The formula for rotation around the y-axis is pi*integrate from d to c x^2 dx.
I'm going to start with a). So what I've learned is that around the x-axis, first I have to find the points from where I'm going to integrate (i.e. integrate from z to y and so on). To get these two points, I'm going to put the curve equal to the line so I know where they intersect.
2.5-x=1/x => 2.5x-x^2=1 => x^2-2.5x+1 = 0 and I get x(1) = 2 and x(2) = 0.5.
So if I'm going to find out the answer, I'll also use (1/x)^2 - (2.5-x)^2. So the total would be:
pi * integrate from 2 to 0.5 for (1/x)^2 - (2.5-x)^2 which gives me the correct answer 1.125*pi.
Okay, so how do I do it for b then?
Take a look here: http://www.wolframalpha.com/input/?i=y=1/x,+y=2.5-x
I want to calculate the volume for the rotation that is both under the purple and blue line. But how do I get that? It is obvious that the "integration limits" are from 2.5 to 0 from that graph. But how do I express it in a formula?
If I do the same as earlier, (1/x) - (2.5-x) Then doesn't that area under the purple line eliminate all of it that is under the blue and then some?
Think of it this way:
You'll get the volume of the figure if you first find the volume under the purple line and the remove the volume [itex]between[/itex] the purple line and the blue curve
So first I'd take the total volume under the purple line. But how do I get the volume that is between the purple line and the blue curve? Purple minus blue and then the total volume under purple minus whatever I got from the second one?
Exactly!
In this and your other recent thread, you have the form of the integral wrong.
For the rotation about the x-axis, y is a function of x, and the integration variable is x, not y, so that should be dx.
The integral is: ##\displaystyle\ \pi\int_{x_1}^{x_2} y^2\, dx ##
  • · Replies 20 ·
