How Do You Determine Electric Fields and Forces Between Charges?
  • Thread starter Thread starter derekbeau
    Charges
To determine the electric field at the origin due to two point charges, one must calculate the electric field contributions from each charge separately, taking into account their distances from the origin. For the second question regarding the forces between two protons, the electric force is significantly stronger than the gravitational force, and the correct ratio can be expressed as Fe/Fg. The calculations for both forces appear to be on the right track, but proper formatting of answers is essential for clarity. It is important to ensure that the distances and signs of the charges are correctly applied in the calculations. Understanding these concepts will help in accurately solving the problems.
derekbeau
I have two questions I am having trouble with, if you could please help me that would be great.
Two point charges, q1 = 4.0×10^6 C and q2 = -1.0×10^6 C, are located on the x-axis at x1 = -1.0 cm and x2 = 3.0 cm
Determine the electric field at the origin
I have no idea how to do this
Two protons are separated by a distance of 1.0×10^10 m (roughly the diameter of an atom). Calculate the electric force and gravitational force on one proton due to the other proton. The electric force is much larger. What is the ratio of the electric force to the gravitational force?
I thought id find the electric force by:
F = [k(1.6 x 10^-19)(1.6 x 10^-19)] / (10^-20) = 2.304 x 10^-8
And find the gravitational force by:
F = [(g m1 m2) / (10^-20)] = 2/742 x 10^-33
I don't know if those are right, but even if they are i don't know how to format the answer
I just need some thorough explination on these two questions, i got all my other ones done.
Thanks
Q1
Because you were given that both point charges are along the x-axis essentially you are just being asked to find the net electric field resulting from the two point charges. Using your equation for the electric field you should be able to find the field for each point and from this the net field. Remember that the distance to the origin is not the same for both charges.
Q2
It's been a while but I believe you are right on. You calculated the electric and gravitational forces and indeed the electric force should be considerably stronger.
When setting up a ratio of the two forces it would be better to write it in the form Fe/Fg or Fg/Fe. Either way you will get the ratio of one force to the other.
ok for Q1 i did
F = kQ / d^2 = [k(4 x 10^ -6)] / 1
F = kQ / d^2 = [k(-1 x 10^-6)] / 9
Then i added these two together but didnt get the correct answer
nvm i got them
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
