How do you differentiate Kirchoffs law?
  • Thread starter Thread starter Needhelp2013
    Differentiate Law
Needhelp2013
How do you differentiate kirchhoffs law which seems to be I = (R+L(di/dt))/V(t)
I need it to be a differential equation so then I can use eulers method.
?? That ]b]is[/b] a differential equation- it involves di/dt. You shouldn't really need to user Euler's or any numerical method: di/dt= (IV(t)- R)/L which can be integrated. I am assuming i and I are different. If you meant i= (R+ L(di/dt))/V(t) then that can be written as L(di/dt)- V(t)dt+ R= 0. For that, with general functions as coefficients, yes, a numerical method is needed. Is there a reason why you specifically wrote V(t), as a function of t, but not L and R?
This is the question I have been asked in full: A resistor R = 15 ohms an inductor of L=2 henries and a battery of E volts are connected in series with a switch S. At time t=0 the switch is closed and the current I=0. Use Euler Method (Excel or hand but show all work on assignment) to find I at time t =.4 if E=10 and h=.1.
I believe the equation of the circuit to be Vt=IR + L(di/dt).This has then got to be converted into a differential equation so that I can then proceed to use eulers method. Yes i and I are different in the equation.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
