How do you do analysis of units?
  • Thread starter Thread starter Ace.
    Analysis Units
The discussion focuses on the unit analysis of the equation relating frequency to the length of a pendulum, specifically the formula f = 5.1L^{-0.5}. The participants clarify the conversion of length from centimeters to meters and derive the frequency formula from the equation f = 1/(2π√(L/g)). The final result aligns closely with the original equation, with minor discrepancies attributed to rounding. Tools such as UnityCalc and Google are recommended for handling calculations involving mixed units.
  • Understanding of pendulum motion and frequency calculations
  • Familiarity with unit conversions between centimeters and meters
  • Basic knowledge of algebraic manipulation of equations
  • Awareness of gravitational acceleration (g = 9.8 m/s²)
  • Research the derivation of pendulum frequency formulas in different unit systems
  • Learn about unit conversion tools like UnityCalc for mixed units
  • Explore the implications of rounding in scientific calculations
  • Study the impact of gravitational variations on pendulum frequency
Students in physics, educators teaching mechanics, and anyone involved in experimental physics requiring unit analysis and conversions.
Ace.
Show the unit analysis of this equation that relates frequency to length (in centimeters) of a pendulum
f = 5.1L^{-0.5}
f = \frac{1}{2\pi\sqrt{\frac{L}{g}}} ?
I cannot find much info about this online, but I gave it a go:
solving for L:
L = \frac{g}{2πf^{2}} * \frac{100 cm}{1 m}
L = \frac{g}{f^{2}} * \frac{cm}{m}
L = \frac{m/s^{2}}{(s^{-1})^{2}} * \frac{cm}{m}
L = \frac{m}{s^{2}}* \frac{1}{s^{-2}} * \frac{cm}{m}
L = cmf = \frac{1}{2\pi\sqrt{\frac{L}{g}}}
f = \frac{1}{\sqrt{\frac{cm}{m/s^2} * \frac{m}{cm}}}
f = \frac{1}{\sqrt{s^{2}}}
f = s^{-1}
Is this the right approach?
I think you are on the write track, but maybe making it more complicated than it is. What the question is getting at is how do you find a formula (starting with eqn 2) that relates frequency to length (eqn 1) and assumes L is in cm. Usually length L would be in meters if using MKS units.
Start with eqn 2, but assume L is given in cm, and convert it to meters.
f = 1/(2*pi*sqrt(L*(1 m)/(100 cm)/g)
f = 1/(2*pi*sqrt(L/(100*g))
f = sqrt(100*g)/(2*pi) * 1/sqrt(L)
If g = 9.8 m/s^2 and pi = 3.14, then
f = 5.0 * L^-0.5
which is almost the same as the original result in eqn1. Maybe some roundoff differences in the constants explain the difference between 5.0 here and the original 5.1 given in eqn 1.
Sometimes you might want to do this rearranging of formulas if say, for example, results you get regularly from the lab come in in mixed units. You could make a formula that handles the unit conversion. However, these days there are also some tools out there that can do calculations with mixed units. All the unit conversion is handled automatically, apps like UnityCalc or even Google.
Hope that helps.
Likes 1 person
  • · Replies 17 ·
  • · Replies 33 ·
